Need Help, Heat Issue?
Old 05-25-2011, 04:39 PM
mfquinn
mfquinn's Avatar
Default Need Help, Heat Issue?
I pulled my rear rotors off to inspect while replacing pads. I have this on both sides. Are these the dust boots for the tie rods? I have heat shields on the front from my Quantum brake cooling kit. But I haven't seen anything available for the rears. I am assuming this is from the heat of the rear brakes. How do I fix/replace?
Old 05-25-2011, 04:53 PM
argonaut
argonaut's Avatar
Yes those are the tie rod boots. You can order new rear heavy duty ones from Ecklers (39964 Tie Rod End Rear Otr HP,97-04). They are fairly simple to replace but its easy to knock your alignment out (toe, thrust) so best to get it realigned afterwards. For future protection wrap them in heat tape or fab up your own heat deflectors.
Old 05-25-2011, 05:17 PM
mfquinn
mfquinn's Avatar
I have an 2008. Same part works for C6? What kind of heat tape would you recommend?
Old 05-25-2011, 05:29 PM
mfquinn
mfquinn's Avatar
that is strange. Part #44432 fits 1997 to 2010 and they are greasable
Old 05-25-2011, 05:56 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Metal tape.
Old 05-25-2011, 08:12 PM
travisnd
travisnd's Avatar
Originally Posted by Jason
Metal tape.
See here: http://forums.corvetteforum.com/auto...int-boots.html
Old 05-25-2011, 08:30 PM
ssdeuce
ssdeuce's Avatar
Just replace the boot then wrap with foil tape
http://www.summitracing.com/parts/ENS-9-13101G/
To Need Help, Heat Issue?
Quick Reply: Need Help, Heat Issue?
