where is the squeek coming from??
Old 05-23-2011, 11:16 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
Default where is the squeek coming from??
changed the tensioner,the idler pullery,the belt,,still squalling like a little girl...how to tell if it's the water pump....'98 C-5 six speed....
Johnny
Old 05-23-2011, 11:42 PM
trackboss
trackboss's Avatar
One simple thing you can do while eliminating sources is to remove the oil fill cap while the squeek is happening. If the squeeking stops it is vacuum related and air is getting past your seals.
Old 05-24-2011, 09:51 AM
stairman
stairman's Avatar
Johnny
Is the balancer coming off.
check to see if it is wobbling and out of line.
Old 05-24-2011, 01:43 PM
vette6aut0x
vette6aut0x's Avatar
Does the car have a/c? If so take the main belt off. If the noise does not go away it could be your a/c. Its on a separate belt.
Old 05-24-2011, 02:03 PM
RAFTRACER
RAFTRACER's Avatar
Isolate by removing one belt at a time as mentioned.....a/c tensioners like to get "out of plane" and make noise....as well as its idler...
Old 05-24-2011, 03:02 PM
travisnd
travisnd's Avatar
I had an chirp I chased to no avail on my old Z06. I replaced the tensioner and both idlers. A buddy told me to try a Gatorback belt and as a last ditch effort I did.... and the car shut up. Dunno why in this particular case that worked, but I was going nuts with a fancy (at the time) car that chirped like a bird.
Old 05-24-2011, 10:07 PM
racerwannabe
St. Jude Donor '06
changed waterpump today,tear into a/c stuff tomorrow...just for grins the noise is now intermitant...gggrrrrr
To where is the squeek coming from??
Quick Reply: where is the squeek coming from??
