Adjustable end links
Old 05-20-2011, 06:35 PM
maxattack
maxattack's Avatar
Default Adjustable end links
I figured this is the section they are used most often. Where/what brand did you buy?
Brandon
Old 05-20-2011, 08:13 PM
ErnieN85
ErnieN85's Avatar
Vette brakes in Fla.
Old 05-20-2011, 08:54 PM
Solofast
Solofast's Avatar
The search feature is your friend....
Here is a long discussion on the subject.
http://forums.corvetteforum.com/auto...-question.html
Old 05-24-2011, 07:54 AM
maxattack
maxattack's Avatar
Thanks guys. Midwest and VB&P are both backordered, got a set coming from corvettesouth.
Brandon
Old 05-24-2011, 09:29 AM
travisnd
travisnd's Avatar
Powergrid
When I removed my GM T1 endlinks I found the bearing race was bent from over-travel of the joint on all corners. These have a much larger ROM than a heim-joint all while being strong and 100% adjustable.
They're not horribly expensive, but not cheap either... best of all no more clinking and clanking that was considered "normal" with the T1 links.
Old 05-25-2011, 07:37 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
LG for me
Old 05-25-2011, 08:47 AM
Aardwolf
Aardwolf's Avatar
Order your own. The mark up is really high on these "kits", looks like five times the cost over retail!
To Adjustable end links
Quick Reply: Adjustable end links
