Anyone know how to make an Airbag simulator?
Old 05-17-2011, 02:50 PM
Charley Hoyt
Charley Hoyt's Avatar
Default Anyone know how to make an Airbag simulator?
I know that Vetteworks sells them...but they are out of stock. Does anyone know how to make them?
Thanks,
Charley
Old 05-17-2011, 04:49 PM
David A
David A's Avatar
I guess it would help to know what year car? To simply turn off the light on my C5 Z06 with race seats and quick release hub, I used a 2.2 ohm 1 watt resistor.
YMMV,
Dave
Old 05-17-2011, 06:11 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Pull the bulb.
Old 05-17-2011, 08:55 PM
Charley Hoyt
YMMV,
Dave
I have a 2008 3LT
Old 05-18-2011, 12:12 AM
Wah
Wah's Avatar
Three Ohms.
Old 05-18-2011, 10:48 AM
ScaryFast
ScaryFast's Avatar
2. That's all.
Old 05-19-2011, 02:29 AM
peterpiper
peterpiper's Avatar
YMMV,
Dave
is that for both the seat and steering wheel? -pp
Old 05-19-2011, 09:37 AM
David A
David A's Avatar
My experience is with my C5 so it has only driver and passenger airbags but the 2.2 ohm resistor "trick" should work with any airbag.
YMMV,
Dave
Old 05-19-2011, 10:50 AM
ScaryFast
ScaryFast's Avatar
One each. The airbag squib resistance is 2 ohm, so that fools the system into thinking the inflator is still in the car.
Old 05-19-2011, 11:09 AM
Dan Wendling
Dan Wendling's Avatar
I dont think that the simple resistor fix will work on a C6 for the passenger seat. It has a weight detector and a second controller that talks to the controller under the driver side seat. So without the passenger controller in place you will continue to get the alarm.
I dont understand what the issue is anyhow. So what if you have a light on in the IP for restraint error?
I simply live with the light, I also have no audible warnings with both OEM seats removed.
Old 07-22-2011, 01:11 AM
LanceFitzgiben
LanceFitzgiben's Avatar
check back with vetteworks, he got some more connectors.
To Anyone know how to make an Airbag simulator?
Quick Reply: Anyone know how to make an Airbag simulator?
