LG GT2 Coilovers...how do you?
Cruise-In VIII Veteran
St. Jude Donor '07
Okay, I have a set of LG GT2 coil overs showing up tomorrow. I am installing them with the Pfadt front and rear budging setup.
How do you get this setup up properly once you install them? I have heard of a four corner setup, but not sure what that is exactly.
Thanks for any advice.
Micah
Micah
before taking anything off mark all the alignment bolts (lower control arms and upper control arms) this will let you get your factory alignment back after install. next find a good race shop who can corner balance - they will put the car on weights and adjust individual spring tensions so that the left/ right weights are equal, this means your car behaves equally when turning left and right. they will also adjust for ride height. finally i recomend some toe-in on the rear wheels to aid in highspeed stability and to point the car straight when it breaks traction. heres mine;
