Bent Valves !!! again
Long story short .... leak down test has showed I have some intake valves leaking causing a drop in peak HP ... this is like my second time this has happened... I honestly never remember any mechanical over-rev not do i bump the limiter often if at all.... Running a stock cast LS6 head ported by TSP and a stock bottom end ... Valve Springs are new Com Cam double versions.... Cam Card I have on file is as below
Gross Valve Lift .612 .612
Duration @ .006 277 280
Duration @ .50 228 230
Lobe separation 113
Lobe separation 113
