c5 shock install issue...
I posted this in the C5 forum, but thought maybe someone here may have seen this before...
I am in the process of changing my C5 shocks to the c6 z06 shocks. The front passenger side went in no issue. The drivers side is where I am having my problem
The front drivers side c6 z06 shock is fouling/chaffing the upper control arm. It's the upper plastic shroud on the shock that is touching the upper control arm. No matter what I do, it seems that I can't get it to not touch the arm.
Search did not turn up anything
When I raise the suspension, like when the car is on the ground, there is no issue. I am just worried something may be wrong with the shock or my suspension components.
Lower right portion of the shock
It is pretty close tolerance when the suspension is full droop.
The plastic cover looks bigger than on the stock shocks.
Your upper CA may have moved, compare both sides at the bushings.
If it clears when down, you really don't have a problem.
2004 C5Z would be a better choice as they are specifically tuned to c5 models.
Post another pic showing the upper CA's both sides (good pic btw)
Thanks for the reply....
I only do HPDE, so I saved the $150 on the shocks. After reading how many people went with the C6 shocks with no complaints I figured it would be worth the saved money .... besides, the driver still ain't worth a darn!
And another guy posted that his also hits in the C5 tech forum, which makes me feel better
Yeah I was gonna do that and thanks for the compliment.. I try to make it easy for people to try and help me!
And I will check them out later when I get home from work and I may post a pic just for the heck of it..lol
normal, at full droop the rear is totally F'd up. Just look at the angle of the upper bushing and it's not square at all. Check it for wear after you've driven some, and I doubt you'll see any evidence of rubbing.
I un-installed and re-installed the shock and it still hits... then I did the rears and they hit too..
lmao.. guess at full droop, they hit.. although they are not much bigger than the previous shocks... about 1/4 inch.. oh well...
and just cause I said I would here are pics of the drivers side upper control arm bushings, they look ok to me, but for those that don't know... I don't know jack!! haha
fwd bushing
rear fwd \bushing..lol
And thanks David, after I lower the car, I will throw some masking tape on there to monitor wear
fwd bushing
Thanks!
Hopefully it will be back on the ground by friday for a test drive on some on/off ramps
And of course, if their are any issues I will be back asking questions
Since we seem to be having our own show n tell in this thread, here are some pics of the lower control arm bushings. The fwd one looks a little odd to me, it looks like it has shifted, but this pic of my drivers side looks very similar to the passenger side.
fwd lwr
rear lwr
They all do that... don't worry about it until the rear edge of the front arm of the LCA is touching the cradle. They you can buy a new OEM LCA or put polys in or whatever.
As the LCA shifts backwards it will adjust your allignment settings so if you see any noticable shifts it may be prudent to have the front end allignment re-done.
The stock setup do "all do that" when driven hard & especially with sticky tires.
Having said that you do have one side measurably different from the other.
So long as you can get the alignment you desire & hold the alignment you are ok.
The front lowers are the ones to watch... I've never had any of the others give me issue.
AHH... rog thanks!
It will be getting aligned next week since I changed all the shocks
Yeah those are pics of the drivers side LWR bushings. The passenger front LWR bushing looks very much the same as in the pic
But, thanks
Changing the shocks shouldn't need a re-alignment unless you've never had it aligned to begin with. You're not changing anything that controls the alignment.
Depends on what you're changing to and from. The KONI 3013Sports, as an example, have a lot more "head pressure" and changed my ride height enough when compared to the C6 Z51 shocks they replaced that I needed to tweak things to get it back happy... also, some of the shocks out there are longer or shorter than stock, etc, etc... always good to check the alignment...
Just cause I like to follow up. lowered the car of jackstands yesterday and there are no clearance issues. Thanks again everyone for the help!
And I took it for a short drive, and the c6 z51 sways, poly bushings, and c6 z06 shocks have sure firmed things up.
