SOUTHEAST RACERS - HEADS and CAM Special for C5 Corvettes
Old 02-24-2011, 03:30 PM
0MTI RACING
Former Vendor
MTI RACING's Avatar
Default SOUTHEAST RACERS - HEADS and CAM Special for C5 Corvettes
LS1 C5 Stage II Special
One of the most popular modifications for your car is “Heads and Cam”.
They give you the true muscle car sound and provide solid power gains.
Best of all, your car still remains driveable for everyday use.
Here’s the package:
1) MTI Racing Camshaft - custom ground by CompCams
Significantly increases power of the engine and gives the car a more muscular idle sound. It also sounds racy at full throttle.
2) MTI Racing Ported Cylinder Heads with matching springs
These higher flowing heads uncork extra horsepower by allowing the engine to breathe better. They give you added power at all rpms. A perfect match with the camshaft.
3) Katech C5R Z-Timing Chain
Super strong timing chain protects against valvetrain failures. 0% failure rate in C5R racecars.
4) MTI Racing Ported Throttle Body
This speeds up the airflow going into the engine, so more power is available without adding any moving parts.
In summary,
If you want a straightforward gain in power and sound, THIS is the package for you! You’ll get an extra 75-100hp and can drive it everyday to work. It will have snappier throttle response and much better acceleration. You can take it to the mountains, drive it to a track day, and still go to dinner with it.
The following special is available at MTI Racing only.
$3995 Parts and Labor, Installed and Tuned**
Call MTI Racing at (770) 919-7774.
Nationwide pickup and delivery transportation is also available.
**(higher mileage cars may need additional misc parts)
Quick Reply: SOUTHEAST RACERS - HEADS and CAM Special for C5 Corvettes
