need harness bar
Old 01-10-2011, 04:33 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default need harness bar
I see all kinds of crappy universal bars on Ébay etc, but I'm not quite that desperate.
Considering going against my rule of putting harnesses in a street car. C6Z06. What units are good (not necessarily BEST, but good/safe), light, and inexpensive.
If anyone has a used one, that's a plus too.
Thanks!
Old 01-10-2011, 05:24 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Thanks!
usually a tough combination but not impossible I hope.
Old 01-10-2011, 06:03 PM
gmccreary
gmccreary's Avatar
I've heard good things about the Shark Bar
http://vetteworksonline.com/Corvette_C6bar.htm
I have the Hardbar harness bar in my C5Z and like it very much.
Old 01-10-2011, 08:01 PM
c4cruiser
c4cruiser's Avatar
The Shark Bar is a very good quality bar and Dan also sells Gary Hoffman's Hardbar. He also has the already-modded quarter panels so you don't have to cut the originals.
Old 01-10-2011, 08:09 PM
sgsvette
sgsvette's Avatar
David,
if you want a bar like I have in my school cars I can get you one for $200 and includes the seat mounting harware for the belts.
Henry
Old 01-10-2011, 08:48 PM
sgsvette
sgsvette's Avatar
pm sent
Old 01-10-2011, 09:24 PM
brkntrxn
brkntrxn's Avatar
You boys in TTU are in for some trouble. David has been devoting 30% of his concentration HANGING ON TO THE WHEEL with stock seats and an OEM 3pt.
David,
Mark N. was trying to sell one recently. If he still has it, Morris can bring it back for you next weekend.
-Kevin
Old 01-11-2011, 12:24 AM
AtomicZ
AtomicZ's Avatar
Brey Krause is the best one. A little more expensive but worth it.
Old 01-11-2011, 12:02 PM
The Stranger
The Stranger's Avatar
What makes it the best compared to the different brands out there?
Old 01-11-2011, 01:18 PM
davidfarmer
I've heared great things about Sharkbar and hardbar, now Brey Kraus. "Best" wasn't a requirement, but I would love to hear more.
Or I may just build one!
Old 01-11-2011, 01:20 PM
davidfarmer
OK, never mind.......$700???? I could build a full cage for that much!
Old 01-11-2011, 01:54 PM
Scooter70
Scooter70's Avatar
Originally Posted by sgsvette
David,
Henry
Can you share more info on your bar or is the offer for Dave only?
Gary's Hardbar is $350 and I've never heard a bad word spoken (or written) about his products.
Old 01-11-2011, 02:19 PM
The Stranger
My sentiments exactly. lol
Old 01-11-2011, 02:42 PM
sgsvette
sgsvette's Avatar
QUOTE=Scooter70;1576482580]Can you share more info on your bar or is the offer for Dave only?
We make our own bars for the Corvette's we have C-5 and C6.
They mount to the original seat belt hole by using a longer bolt. All you have to do is drill a hole in the plastic cover the size of the bar and that's it. It also comes with seat rails that mount to your existing seat bolts. All you do is take the nut off, place the rail on and then put the nut back on. Now you hook your belts to it.
Simple, not fancy. Inexpensive way to have a 5 or 6 point harness.
$250 plus shipping.
Old 01-11-2011, 02:46 PM
The Stranger
$250 plus shipping.
I may be interested in something like this. Do you have any other pics? Maybe even some of the way it's mounted.
Old 01-11-2011, 04:04 PM
sgsvette
sgsvette's Avatar
It's mounted with just a bolt at each end. Just longer than your seat belt bolt.
Old 01-11-2011, 04:51 PM
The Stranger
Is it possible to have a bar made with the belt separators like the sparco bar has?
To need harness bar
Old 01-12-2011, 02:29 PM
vettedan
vettedan's Avatar
Like the Sharkbar!!!
Old 01-12-2011, 08:53 PM
RX-Ben
RX-Ben's Avatar
I like the Arizona Speed & Marine bar as well as the B-K - both are low enough to get the recommended should harness angles. Many/most available force the harnesses to angle upwards (out of spec).
The Sharkbar separators pictured are largely useless. You want separators to keep a constant (ideal) distance btw the belts where they wrap around the bar. Some roll bar padding and zip ties will do the trick.
Old 01-13-2011, 03:40 AM
bobmoore2
bobmoore2's Avatar
The pictures of the Hardbar (in posts 14 & 15) and of the Sharkbar (in post # 18) show a racing harness used with a Corvette seat that does not have pass-throughs for the shoulder straps.
This is bad Bad BAD, because the shoulder straps can not go over the shoulders in the correct position. This is even worse than the stock belt's shoulder strap.
PLEASE, do not do what is shown in those pictures.
Quick Reply: need harness bar
