T1 sway bars of Pfadt's?
Pfadt Heavy Rate are bigger than the T1s and almost adjust in to the T1 range.
Are you sure you need "the most aggressive"? Swaybars are best set by testing, testing, testing and checking your lap times... although I have to admit that having the front end nice and flat sure does feel good.
As to me needing the most aggressive bars, I agree that repeated testing and lap time comparisons are my best bet for achieving the best set up, but since the swaybars are so expensive I figure I might as well get the most aggressive bars and dial back if necessary. If that makes sense?
Maybe. I think I have GM's rear C6 base, C6 Z51, and C6 Z06 bars, plus Pfadt's Original Pfattys. I've messed with them all in various combinations on the car. The GM bars are fairly inexpensive. Other have had good luck with the ADDCOs, too. You can buy a lot of bar combos for the money if you don't mind swapping rather than just changing holes. :-)
Or buy a set of coilovers with the proper springs and the right amount of adjustability and you will need very little bar.
I use a base option C6 front bar and no rear bar on my C5 coupe.
I think he's saying the HR bars are too stiff for most of us, and I agree. I can't imagine needing a bar that stiff unless you are running a 4000lb vette.
If you're going to be running big bars (like T1 rates), what's the rest of your suspension look like? They work well with stock springs and even slightly bumped springs, but if your car is stiffly sprung you don't want to be messing with big honking bars.
The only way I'd run T1 bars is w/ a softly sprung (near stock) car.
But I am only comparing to the OEM 04 C5Z set up, and that's all the experience I've got.
yeah, T1 bars are great w/ stock springs. Bigger sway bars are a nice way to make a street car more trackable, in that it doesnt really affect the bump harshness in the way stiffer springs do.
Cool. I guess I lucked out with my choice being that I have next to zero experience compared to you.
Seems like I may not even "need" coilovers. Maybe replace the shocks with the Koni FSD, keep the facatory c5 z06 springs, and get T1 bars.
