Installing ARE Dry Sump
Who has installed the ARE Dry Sump system while keeping the OE type springs? Looking to mount the oil filter behind the front inner left fender, this is workable although not real convenient.
Where have you installed the oil filter assembly?
Looking for input and ideas
Hello
I just installed are on my car. The oil filter is placed on the drivers side up/in where you originally hsve the two bolts for the leaf spring. A bracket was made, and the oil filter is sort of tucked away up-in there on the front lh corner of the engine.
Brgds
Brgds
Former Vendor
Former Vendor
I agree with Randy, easiest place to mount it is in drivers side front fender. Shortest lines, away from headers. A little more work to change oil but it's not like you do that everyday. If I get time, I will pull car out and snap a shot.
Robert Finlayson
Performance AFX Motorsports
Robert Finlayson
Looks like your behind the front wheel? What is required to get the filters removed. I was looking at front of the wheel near the brake air duct. I think the air duct can be removed when its time for the oil change and not removing the inner fender.... or am I just dreaming
Randy.... what's your thought front or rear of the fender area
The rearmost inner fender panel comes out as easy as the brake duct....
Where is your washer tank?
