F/S C5 Moton Triple Adjustable Shocks
These were off the 2003 Z06 T1 car. This is a great opportunity to pick up some $7,000 shocks CHEAP.
You can send these to Moton and have the following parts replaced and still be into these at a great deal.
1 Front shock/canister assembly ready to bolt on car
1 Rear shock/canister assembly ready to bolt on car
The needs:
Other Rear shock-
Replace and rebuild other rear lower shock clevis only. It is bent where it mounts to the control arm as seen in picture. The remote resevoir is perfect and needs the hose line replaced.
Other Front shock-
Replace canister shell housing & shaft and rebuild. Also needs new hose as it has small slit in it..
You can call and talk to Lex at Moton for any further questions about these shocks and what it may cost to repair what I explained.
Lex 770-886-8777
Price shipped $800.00
Aaron
The needs:
Other Rear shock-
Other Front shock-
Lex 770-886-8777
Aaron
Hi Aaron:
I just sent you a PM.
Oli
Oli
