Looking for advice from the experts
Old 12-30-2010, 07:12 PM
JohnAlley
JohnAlley's Avatar
Default Looking for advice from the experts
I will be doing NASA HPDE's and then hopefully TTA and maybe PTA in 2011. I have a 2004 Z06 and am planning on doing the following:
1) Stop-Tech Aero Rotors on the front
2) Power Slot Rotors on the rear
3) Stop Tech SS Brake Lines
4) Carbotech XP10 on the front
5) Carbotech XP8 on the rear
6) Pfadt Heavy Sway bar
7) Not sure on tires maybe R888's for HPDE
8) Hoosier A6 for TTA
For those who have been doing this for awile what have I missed or need to change ?
Old 12-30-2010, 07:59 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
I am no expert but since you are in Indiana, may I suggest seat time with 10/10ths if I am correct in assuming you are just beginning track events. You will get real fast and consistent quickly at Putnam Park. Many events there this coming year with 10/10ths.
http://www.1010thsmotorsports.com/page/page/5236308.htm
Old 12-30-2010, 08:06 PM
davidfarmer
davidfarmer's Avatar
does Pfadt recommend the HD bars for stock springs???? I have no firsthand experience, but that is a LOT of bar for OEM springs. Maybe a good mix, maybe trouble.
Other than getting your weight down, not much else allowed to do. Maybe brake ducts.
Old 12-31-2010, 06:09 AM
gkmccready
gkmccready's Avatar
[Edit] To original poster: Unless you've done a tonne of track days, just get out and enjoy HPDE and don't modify the car until you're turning consistent, fast laps. You've got most of what you'll want sorted out. Watch temperatures (water, oil) and go from there.
http://www.nasaproracing.com/rules/p...ring_rules.pdf
5.3.I No-points modifications
  • Lightweight battery (relocated to where you need the weight)
  • Lexan Windows
  • Air Filter Upgrade (in stock location)
  • Radiator Upgrade
  • ECU Tuning
  • Oil cooler
  • Lightweight Wheels
  • Ultra-light clutch/flywheel
  • Motor/trans/diff mounts
  • Poly suspension bushings
  • Brake ducts
  • e-Brake removal
  • 2pc brake rotors
  • Driver & passenger race seats
TTA/PTA taken to the max of the rules can be pretty expensive by the looks of it. And that's without really looking at using the points available.
Obviously PTA will require a 6-point cage. :-)
Old 12-31-2010, 08:07 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Not really sure why everyone is trying to reinvent the wheel, do your research all the set ups that work have been posted including the fastest TTA C5Z that's been around Mid Ohio (Which is the only track that counts for the next two years)
Old 12-31-2010, 08:18 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Swaybars, clutch, A6's. Go.
Old 12-31-2010, 08:21 AM
L98Terror
L98Terror's Avatar
What I did find is the T1 bars seemed to slow me done at places like Putnam, Gingerman and Grattan but were fast as hell at Mid Ohio
Old 12-31-2010, 09:13 AM
JohnAlley
JohnAlley's Avatar
I have run 5 HPDE 's in 2010 so still consider myself really new to this. 10/10ths is on my schedule for 2011. Putnam Park is real close to where my daughter lives so I can drop off the wife and then go play.
Old 12-31-2010, 12:03 PM
Zenak
Terminal Vette Addict
Zenak's Avatar
Did you read:
http://forums.corvetteforum.com/auto...e-learned.html
Old 12-31-2010, 04:34 PM
SouthernSon
Great! Bill runs a safe event with lots of track time. You may want to look at the VIR event in March if you are able to make it. There will be plenty of folks there that compete W2W in other venues and work on their vehicles and know what a person needs. Any of us will be glad to ride with you and answer whatever questions you have. But, I suppose the biggest draw to 10/10ths motorsports is the fun. You will have fun! Look forward to meeting you.
Old 12-31-2010, 04:41 PM
sperkins
sperkins's Avatar
for TT.
PTA would be a little different, but either way you'll have to do a lot of the "free" mods to be competitive in a good field.
Old 12-31-2010, 05:00 PM
drivinhard
drivinhard's Avatar
Swaybars, clutch, A6's, AP Racing Brakes, Penske Shocks. Go.
fixed
Old 01-01-2011, 12:36 PM
90pololt4
90pololt4's Avatar
Phadt's HD bars have worked great with stock springs & shocks on our 01 Z06. Lots of lube to keep them quite. The next step is to upgrade to better shocks.
Old 05-04-2011, 10:10 PM
Z06Tracker
Z06Tracker's Avatar
These free mods are great, but they are costing me a lot of money. I can't seem to get the needle out of my arm!
Originally Posted by sperkins
for TT.
Old 05-04-2011, 11:01 PM
drivinhard
drivinhard's Avatar
man you haven't even gotten to 2 pc rotors, lexan, cage, 5" clutches, carbon fiber hoods, 3.90 gears, and all the other good "free" stuff
Old 05-05-2011, 11:22 AM
yakisoba
yakisoba's Avatar
I'd suggest you get a dyno run done, and tune your weight to that, as close as you can. If you are going to run Hoosier A6, they will be starting to fall off after around two laps, at most tracks. That means getting your weight down. I'd try the 255 tires, as they are as wide as the 275, and worth less points (in the 18" wheel).
Typically, you can get away with around 380 RWHP at stock weight, with those tires and so forth. If you do decide to drop weight, there is a sweet spot at 3201 pounds, and another at 3151. The lower limit (unless you are seriously down on power) is 3118, with you in the car. Adjust your HP accordingly, but it'll be more rewarding to drop weight than to add HP, most of the time.
Old 05-05-2011, 12:29 PM
Pumba
Pumba's Avatar
1) Ron Davis Racing or DeWitts radiator
2) SETRAB Pro-Line #172 oil cooler and #12 AN lines
3) Stop-Tech Aero Rotors on the front
4) Power Slot Rotors on the rear
5) Stop Tech SS Brake Lines
6) Carbotech XP10 on the front
7) Carbotech XP8 on the rear
8) Pfadt Heavy Sway bar
9) Not sure on tires maybe R888's for HPDE
10) Hoosier A6 for TTA
Before you add all this traction and braking capability to your Vette, you need to protect the engine with better cooling of its oil and water ! !
To Looking for advice from the experts
Old 05-08-2011, 02:25 PM
Z06Tracker
Z06Tracker's Avatar
Don't remind me.....
Old 05-08-2011, 02:38 PM
brkntrxn
brkntrxn's Avatar
Not if you are running TTs, the extra cooling just becomes excess nose weight. The tires are done by the time the oil temps hit 290*.
W2W in PTA is a different story.
Old 05-08-2011, 02:45 PM
brkntrxn
brkntrxn's Avatar
4) Carbotech XP10 on the front (XP12)
5) Carbotech XP8 on the rear (XP10)
7) Not sure on tires maybe R888's for HPDE (or NT01s or RA1s)
Go with what you have above. Get the car tuned and shoot for low 370s at the wheel. Then pull weight from the car to get to your hp:wt ratio. After that, run it hard.
Quick Reply: Looking for advice from the experts
