Clutch recommendations
Old 12-25-2010, 12:21 PM
Rob P
Rob P's Avatar
Default Clutch recommendations
My clutch seems to be going on me. What clutch do you recommend?
I am at 420rwhp and want a clutch to hold up to 500-600rwhp
The stock clutch was crappy for me. I need something that has good pedal feel as well.
this is for a c5z06
Old 12-25-2010, 01:42 PM
Last C5
Last C5's Avatar
I just installed a Fidanza 7.6 dual disc in my 01 Z. Clutch feel and engagement is great. I used the aluminum flywheel so I have to compensate a bit for it, but with a billet or steel flywheel the engagement should be very close to stock. The clutch is rated to 900 hp so it should work for your application, plus it goes in with stock hydraulics.
Quick Reply: Clutch recommendations
