New Racing Seat Mounting Brackets Coming Soon!
Former Vendor
We will have our NEW C5/C6 mounting brackets with sliders available in January.
We have modified our bracket shown above in the following ways:
1) The rails under the sliders have been widened to better accommodate seats of varying widths. The rails have slotted holes so the sliders can easily be moved inward or outward for optimal fit.
2) The side mounts have a new, wider base. If you spread the sliders and side mounts out as far as they could go they would be nearly 20" wide!! Of course, no seat with a base that wide would fit in the car but that should allow for plenty of room for seats that need to be off-center to fit in the car to be installed.
3) The rear harness mount locations have been modified and lowered to prevent any interference with slider travel.
We expect these brackets to work fine with EVO2 Plus, EVO2 and other popular wider seats that are known to fit in the car without modification. We hope to have feedback on EVO2 Plus seats with these brackets in a C6 within a couple of weeks. If a seat has wide shoulders and touches the door, of course our bracket won't prevent that. The seats we have test fit on the bracket thus far have gained headroom if needed.
The pricing will increase $20 when all the new components are available. Any who order the brackets now will pay the current price and have the option of waiting for the wider version if desired. When you get your confirmation order email, just reply with a message to send the wider brackets in January.
http://www.arizenracingsports.com/pa...OD/C5-C6/C5MBR
I'v been looking for a high quality adjustable seat mount for Kirkey's road race seat. Will this seat mount work in this application? What is the clearance from the floor to the top side of your mount and what hardware is included?
Former Vendor
I am not sure on the Kirkey seats yet. Someone was planning to try an install with a 17" Kirkey seat but we are waiting for feedback. I am not sure if the holes in the sides of the seat line up with our side mounts.
Former Vendor
The customer who wanted to attempt installation with a Kirkey seat had a 41 series. He mentioned the angles of the seat base might cause an issue with the side mounts but we still haven't heard back from him with details yet. I can give you the dimensions on the side mounts to compare to your seats If you'd like.
Former Vendor
They can be ordered thru the link below.
Former Vendor
We have a few sets of our new wider brackets in stock. They should work with most side mounted seats that fit in the car.
Former Vendor
Former Vendor
Former Vendor
There also will be a tab bent upward on both sides of the bracket. We previously had it on the tunnel side only for those wishing to mount their stock seat belt buckle. Since the C6 needs a location to bolt the belt itself on the door side, we are adding it.
We should have the new brackets within 2 weeks.
I am assuming this would work with a Sparco Evo without any issues.
Subscribing for status update. At some point I need to replace the speedware bracket i have in case I ever need to pull the seat out again (it doesn't go back in very well).
Former Vendor
It's been used often with the EVO2 Plus in the C6. The standard EVO shoulders are listed as wider and the seat belt retractor might make it tight in the back but if you already have it in the car I would expect it to fit on our bracket.
