Silly T1 shock question
Old 12-12-2010, 09:47 PM
mikemiller68gs
mikemiller68gs's Avatar
Default Silly T1 shock question
I picked up a set of used T1 shocks. I went to install them on my 99 today. they didn't include any of the bushings. That's no big deal except I'm not sure what all i'm missing. What bushings should be under the dust shields(?) front and rear. Thank you in advance for any help
Mike
Old 12-12-2010, 10:21 PM
sperkins
sperkins's Avatar
There are no bushings under the dust shields. The dust shield sits on top of the snap ring on the shock shaft. If you're reusing the bushings from the shocks that are currently on your car, just reassemble everything in the same order you took them off.
Old 12-12-2010, 10:39 PM
mikemiller68gs
Perfect. Thanks. My Bilsteins had bushings under the snap rings. Thats what confused me.
Mike
Old 12-13-2010, 12:25 PM
mgarfias
mgarfias's Avatar
Mike
Bushing or a bump stop?
Old 12-13-2010, 02:24 PM
mikemiller68gs
I'm guessing it was a bump stop on the Bilsteins. The T1 shocks had nothing
Old 12-13-2010, 10:05 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I would not expect much from a set of USED T1 shocks.....they are great for a season, but won't hold up long if they are used at the track.
Old 12-14-2010, 01:05 PM
sebdavid
sebdavid's Avatar
What do you mean? Are they notoriously short-lived? How many track days before they need a rebuild? Are they that fragile?
Old 12-14-2010, 01:27 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
all OEM shocks are low bid items and go down hill fast. OEM's pay peanuts for a shock on the average car. Few years agog it was about 9-11 bucks I read
To Silly T1 shock question
Quick Reply: Silly T1 shock question
