AMSOIL at Wholesale for Track Day Forum Members
Old 12-05-2010, 10:29 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Default AMSOIL at Wholesale for Track Day Forum Members
Track Vette Drivers,
If you are interested in trying AMSOIL Synthetic Lubricants for your track or tow vehicles, I'd like to ensure you get your fluids at dealer wholesale, about 25% below retail, via the AMSOIL Preferred Customer Program. Please drop me a PM or email at c66racing@hotmail.com for more info on this program - I'll answer your questions usually in the evening when I get home from my other full time employment.
Track Day/Racing Oils:
AMSOIL makes several grades of Group IV, polyalphaolefin (PAO), synthetic basestock lubricants that meet the various needs of track day or racing Vettes, including track only, dual use (track/street) and with or without oil coolers. All of these contain high levels of ZDDP, or Zinc dialkyl dithio phosphate.
Note: None of these meet GM Standard 4718M
AMSOIL Dominator Synthetic 10w30 Racing Motor Oil
(Product Code RD30QT)
(zinc – 1575 ppm, phosphorus 1474 ppm)
(No detergents)
(This is the oil I use in my SCCA T1 02 Z06)
AMSOIL SAE Synthetic Premium Protection 10w40
(Product Code AMOQT)
(zinc – 1378 ppm, phosphorus 1265 ppm)
(High levels of detergents/dispersants suitable for extended street use)
AMSOIL Dominator Synthetic 15w50 Racing Motor Oil
(Product Code RD50QT)
(No detergents)
AMSOIL SAE Synthetic Premium Protection 20w50
(Product Code AROQT)
(zinc – 1379 ppm, phosphorus 1266 ppm)
They also carry a full line of Group IV, polyalphaolefin (PAO), synthetic basestock transmission and gear lube fluids.
C4 manual transmissions (89 and later): AMSOIL Synthetic Synchromesh Transmission Fluid (MTF) (Product Code MTFQT)
(Pre-89 PM me for info - several fluids available depending on your transmission)
C5/C6 manual transmissions (Dexron III):
AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G)
(This is the fluid I use)
C5/C6 (05s) automatic transmissions (Dexron III)
AMSOIL Universal ATF (Product Code ATFQT)
C6 automatic transmissions (06 and later) (Dexron VI)
AMSOIL Low Viscosity Universal Automatic Transmission Fluid (ATL) (Product Code ATLQT)
C4-C6 Gear Lube:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
Note: The Severe Gear fluid comes with friction modifier already in it and most C4 and C5 differentials do not need extra additive to prevent diff chatter. C6 diff clutch plates behave differently than earlier Vettes and for C6 diffs I recommend one bottle of the Slip Lock Additive.
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
AMSOIL Hand Pump (Product Code G2039)
(Works with any off the transmission or gear lube bottles listed above - I use two, one for gear lube and one for tranny fluid)
Brake/Clutch Fluid
AMSOIL Series 600 DOT 4 Racing Brake Fluid (Product Code BF4SN)
Dry Boiling Point - 580F, Wet Boiling Point - 410F
Note: Owner's Manual Requires DOT 3 Brake Fluid
Power Steering Fluid
AMSOIL Synthetic Power Steering Fluid (Product Code PSFCN)
Coolant Additive (similar to Red Line Water Wetter)
AMSOIL Dominator Coolant Boost (Product Code RDCBCN)
Info on the multitude of products available for your tow and support vehicles, including CI-4+ diesel oils for pre-07 diesels as well as CJ-4 diesel oils for 07 and later diesels, can be found via this link:
AMSOIL Online Product Application Guide
Orders placed direct with AMSOIL using reference 1206638 will benefit my race team and the forum: AMSOIL Ordering Information
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Quick Reply: AMSOIL at Wholesale for Track Day Forum Members
