Brake rotors
Brake rotors
OK
So my rotors are about ready to go. And I bought some replacements from Rock Auto. Good prices BTW...
Anyhow I have two front rotors that are identical. Meaning the vanes in them go the same direction and the cross drills in them also go the same direction C6 Z51's). So I have two left rotors instead of a left and right? Looking at the old right side one it clearly goes the other way.
So my question here is? Does it really matter at all? I mean the air flow will be a bit different and they still have the same number of holes at the same radii from the center, but does it matter which way the vanes inside the rotor are going? Should I care about this or just throw the new ones on when the old ones finally crack?
Mike
Mike
Former Vendor
The stock C6Z rotors are the same way, and yes they are incorrect. You want the vanes to pull heat away from the center as you are moving forward, not forcing air into the center when you are moving forward.
With directional vane rotors, there is a left side and a right side.
Daniel
http://www.finspeed.com/
Daniel
CI 4-5-6-7 Veteran
Are you tracking the car or just street driving? On the street I wouldn't worry about it. On the track, I'd probably run them anyway. On track they're not going to last long enough to make it worth shipping it back and waiting on a replacement, which may or may not be exactly wrong again. I've run them backwards when I've run out spares for one side or the other. BFD to me. YMMV.
So really not a big deal here... I do track the car, but not often enough to replace the rotors all the time, and first thing I did was duct the fronts with a Quantum kit so they should get plenty of air either way... Think I'll just put em on bass-ackwards on one side :
Thanks for the feedback!
Check the part numbers on the packing slip against the order confirmation email you received. Most drilled/slotted rotors (and especially ones with angled vanes between the rotors surfaces) will have different part numbers for left and right. Also check the part number on the boxes.
If you ordered the correct part numbers for left and right, either the picker grabbed a wrong box, the box was mis-labeled or had the wrong rotor in the box. Rockauto is pretty good about fixing a screw-up as long as it's on their end.
No big deal I guess.
Thanks again
Mike
Received 8,918 Likes
The stock Z51 and Z06 rotors are only facing the correct way on one side of the car. When GM was doing the Ring testing they didn't find much difference between facing the supposed correct way and not facing the correct way. The rotors get hot and the air inside of them expands that along with centrigugal force makes the air flow from the center to the outside.
I run the stock Z06 rotors and after several track days the front ones although directional seem to heat check and crack within an hour of each other with no prevalence of one side going before the other.
Since the OEMs are not designated right or left side I doubt the aftermarket ones will be any different. If you send one back you will get the same thing.
Bill
Bill
So, I accidentally had a set of NAPA rotors facing the wrong way... and they clearly had a lot more heat checking and cracked *much* faster than when you face them the right way. The whole idea that only doing a left or right side rotor is a good idea is easily disproved...
