DRM radiator and engine oil cooler brought my temps down 40+ degrees!
I used to see 300+ engine oil temps running in 80 degree weather within 5 laps. With DRM's radiator and engine oil cooler today I maxed out at 265 oil temp at the end of 20 minute sessions. Outside air temp was over 100!
Thanks Randy,
Matt
Thanks Randy,
Matt
Me too! I was hitting 300F+ on the oil and didn't pay attention to the water. Put in the DRM/RD combo radiator on my C6 Z51 and water basically sat steady between 195-205F with a stock thermostat in the car. Oil temps were similar to yours which was a great difference!
300 degrees is way, way to hot?
I don't see how the motors live with those oil temps?
265 degrees is hot, that is the threshold of "nervous"?
I would propose the gauges are reading 20 - 30 degrees high????
No doubt the coolers work, mine dropped oil temps 40- 60 degrees. Now oil runs a balmy 210 degrees
TJM
TJM
Former Vendor
TJM
TJM
This is the nature of all C5 and C6 corvettes. Hot hot and hot... You should check the diff temps There is no way 100's of cars have bad temp sensors.
Randy
Mobil 15w-50 helps keep the viscosity somewhat reasonable at those temperatures.
While the engines are capable of living at those temps, I didn't like the power loss as the computer dialed back the timing and I HATED having to baby the car for a lap or two every 5 laps to get the temps back down.
Now I just keep the hammer down for the full session!
Matt
Don't go on my word though, do your own research to validate my findings that I don't fully recall as it was four years ago that I did it.
Oli
The concern at those elevated temperatures is less about oil viscosity per se than it is changes in running bearing clearances. On rod bearings, which are all steel journals, it's viscosity. But on the main bearing clearances. keep in mind that LS motors, being alumimum block motors, have significant growth in main bearing clearances (where the block side of the bearing assembly is backed with aluminum, though the cap-side is steel) as temps go up. When I used to build engines at Roush-Yates in NC, which were also aluminum block, we would see the bearing clearances double from ambient to 210 oil. The growth from 210 oil to 300 oil would be another 0.0007"-0.0008" which is significant. If we saw oil temps rise above about 270, unless it was during the race, we'd shut it down.
FWIW, we did some controlled oil testing on the dyno and consistently found Mobil 1 to run the coolest and make the most power.
What I would recommend is, if you break 270, back off, cool down and hit it again. Then, when you get home, order an oil cooler.
Great information !
I was at a Corvette Corral during a Mid-Ohio ALMS race and a Corvette engineer attached to the Pratt and Miller cars told the assembled Corvette owners that the P&M ALMS Corvettes shut their engines OFF if water temperature reached 190 degrees F.
He also stated that their oil temperatures were in the 210 degrees F to 220 degrees F range.
Great information !
I was at a Corvette Corral during a Mid-Ohio ALMS race and a Corvette engineer attached to the Pratt and Miller cars told the assembled Corvette owners that the P&M ALMS Corvettes shut their engines OFF is water temperature reaches 190 degrees F.
Getting back to the topic of stock LSx aluminum engines....
The T1 guys tend to laugh at the temperature warnings. They use Mobil 15W-50 and coolers.
Additionally, most driving schools (Spring Mountain, Bondurant, etc) that have run C5s and C6s do just fine running them hard in the desert heat all year long.
I was perfectly comfortable with the temperatures I was seeing before, but now with my DRM radiator and engine oil cooler I can push hard all day long and just have fun. In fact, I had so much fun on Monday I corded my tires!
Matt
Matt
I am in the market for a combo rad. I went to their site and only saw the Ron Davis, and nothing for the C6Z. Did I miss something?
Former Vendor
Randy
763-477-9272
If you want proper cooling get a separate air-oil cooler. My T1 car oil temps were 225 or less running back to back 25 minute sessions at VIR in 90 degree heat. The guy next to me had a combo rad and his temps were up in the 270's running in the same conditions.
Tim
Tim
I am running the air-oil cooler that comes on the C6Z, and it's not cutting it. With a 468 LS7 I think I'm going to have to run a combination between the stock cooler and a rad cooler.
I have a 454 LS7 and the boys over at DRM fixed me up. I was running way too hot on the track. Randy will get you sorted out properly.
Was this the DRM/Ron Davis radiator with built in oil cooler?
