torque spec for exhaust manifold on Z06?
Old 07-09-2010, 01:47 AM
Dirk Miller
Dirk Miller's Avatar
Default torque spec for exhaust manifold on Z06?
Does anyone know the foot lb torque spec for bolting exhaust manifolds onto the ports of the engine block on a 2007 Z06?
I was surprised the bolts were not too tight when I dissassembled my
exhaust manifolds off of my '08 C6. I am installing an '07 Z06 manifold and pipes but do not know the torque settings. Wondering who out there might know?
Old 07-09-2010, 02:15 AM
GettReal
GettReal's Avatar
http://www.davidfarmerstuff.com/C6-Torque-Auto.PDF
2nd page under Engine. I love having access to Davids Info. Thanks again David
Old 07-09-2010, 07:34 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Z06 specs are here
http://www.davidfarmerstuff.com/C6Z06-Torque.pdf
might be the same though. It says torque to 11ft lb, then to 15ft-lb for final
To torque spec for exhaust manifold on Z06?
Quick Reply: torque spec for exhaust manifold on Z06?
