Tow Hook for C5 - Screw in Eye Hook Style - Where?
Old 07-05-2010, 01:32 PM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
Default Tow Hook for C5 - Screw in Eye Hook Style - Where?
Where to get them? Who makes them?
I don't want the hinge kind, dont want the protruding kind since i still street the car now and again.
Anyone? Where did you install it? Pics?
Old 07-05-2010, 01:56 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Phoenix
Old 07-05-2010, 01:58 PM
MySR71
MySR71's Avatar
I'm pretty sure that GM makes one for the export C6's. I wonder if they could be adapted to the C5. Check out item #13.
http://www.gmpartshouseusa.com/partl...layCatalogid=0
Old 07-06-2010, 01:42 AM
rgg16g
rgg16g's Avatar
Looks like this could work.
http://www.corvettec5.de/PDF/C6EUhookC5.pdf
http://forums.corvetteforum.com/c5-t...y-on-a-c5.html
Old 07-06-2010, 06:46 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
If you get the hinged tow hooks you can put a pin where the hinge is which will allow you to take the hook part off when not in use.
Old 08-09-2010, 10:39 AM
Larry Bittner
Larry Bittner's Avatar
The attached flyer is for a removable hook that installs in about an hour without removing the front bumper.
File Type: pdf
File Type: pdf
To Tow Hook for C5 - Screw in Eye Hook Style - Where?
Quick Reply: Tow Hook for C5 - Screw in Eye Hook Style - Where?
