Help: Quantum Spindle Ducts
I was in the process of installing the kit when I noticed 4 bolts were missing from the kit (2 bolts per side). Does anyone know what type of bolt and what length (see pic)?
Thanks!
Also, it's the kit for the base/Z51 C6
Thanks!
Former Vendor
I cannot get to mine right at the moment but something like
1/4 20, 2.5" long(maybe longer) a lock washer and nut for the outboard end to hold it in place.
The next size smaller than 1/4 is fine I am sure as well as metric.
Then a locknut and flat washer on the tab that goes over the brake caliper ears, tightened down to keep things from rattling around, rubbing etc.....
Hope this helps!
Rick
Hope this helps!
Rick
