Toyo R888s
Old 06-25-2010, 09:13 PM
gmccreary
gmccreary's Avatar
Default Toyo R888s
Anyone one running Toyo R888s on stock C5Z wheels? If so, what sizes?
Old 06-25-2010, 09:19 PM
Todd Z
Todd Z's Avatar
Your best bet is to get 18X10.5 all the way around. Easier to get tires.
Old 06-25-2010, 10:16 PM
mgarfias
mgarfias's Avatar
I think I've come to that conclusion, would run a 275/35/18 and a 305/35/18. Does that make for a decent combo?
Old 06-25-2010, 10:19 PM
kmagvette
kmagvette's Avatar
and 305's on all four corners. R888's will last a very long time on the track...they slide around a bit, like higher pressures, are freaking heavy, and just keep on going. Shoulders stay pretty squared up if you run a bunch of neg camber -2.5 or more.
Old 06-26-2010, 12:03 AM
sperkins
sperkins's Avatar
Go Nitto 555R2 or Proxies RA1.
For stock wheels:
275/40/17
305/35/18
Or if you can pick up 2 more 18" wheels go with:
285/35/18 Nitto on all four corners. (no active handling though).
http://www.nittotire.com/
http://toyotires.com/tire/pattern/proxes-ra1
Old 06-26-2010, 12:24 AM
Joy of 6
Joy of 6's Avatar
For stock wheels:
275/40/17
305/35/18
This is what I am running on stock wheels
To Toyo R888s
Quick Reply: Toyo R888s
