Z51 Sway Bar Question
I have an 08 1LT with the base suspension running RE-11's on all 4 corners. I am upgrading the brakes to the Z51 upgrade and was also looking at the Z51 sway bar. What advantage/disadvantage will i see with just changing the sway bar without any other suspension mods?
Also which brakes pads are most people using for a daily driver that autocrosses every other weekend with Z51 rotors?
The Z51 bar will make the car stay "flatter" when cornering but will induce a bit more understeer. It will keep the car more settled in transitions and slaloms.
A guy I ran against last year (we were 1 and 2 in our class and I have Z51) had a base coupe with a Z51 front bar and Z06 shocks and it was a great setup on good street tires - he ran kumho XSs - I think the RE11s are faster.
I ran Carbotech 8s and 6s - good pad but very noisy and dusty. You should do fine with Z51 or Z06 pads.
Hoosiers solved that problem
