Stupid question about camber gauge
Old 06-21-2010, 08:29 PM
Everett Ogilvie
Everett Ogilvie's Avatar
Default Stupid question about camber gauge
OK, I got my new caster/camber gauge (the bubble/vial type) and it came with the magnetic adaptor. How the heck does one attach a magnetic gauge to an aluminum wheel..... it says to attach it to the spindle, but the adaptor will not fit through the wheel center hole to contact the spindle.
Old 06-21-2010, 08:37 PM
dvandentop
dvandentop's Avatar
interested to know also
Old 06-21-2010, 08:38 PM
NMsharkracer
NMsharkracer's Avatar
Location: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Everett,
I just had a thought after our talk Saturday. If you take off the front wheels and support your suspension at or near the lower ball joint on jack stands, the spindles would be at their loaded position and you could do the +/- 20* rotation without slip plates. Someone want to tell me if I'm in error?
Old 06-21-2010, 08:43 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
I went through the same thing. I ended up buying the tripod mount that you hold against the wheel and use that instead (I assume it's a Longacre?).
Old 06-21-2010, 08:52 PM
Everett Ogilvie
Will my gauge work with the tripod mount, or would I need a whole new gauge?
Jack - I also wondered about removing the wheels/tires and letting the rotors sit on wood blocks so the suspension is compressed to the normal ride height. I suppose that might work for the camber, but for checking caster you need to turn the wheels back and forth.
Surely someone has figured out a way to make the magnetic adaptors work?
Old 06-21-2010, 08:53 PM
Rob31
Rob31's Avatar
I have a steel gear that I use as a spacer for camber . Caster , I take a rubber strap (bungee) attach each end to a spoke in the wheel.
I want to get a set of car dollies,so I can just bounce the car instead of rolling back and forth to settle the alignent change...anyone try this?
Those Snap-On turntable plates are pricey
Old 06-21-2010, 08:58 PM
trackboss
trackboss's Avatar
If the wheels allow it, stick it to the rotor. Otherwise its not really useful. Get yourself a 2x2 length of square tubing long enough to get to either the rim edges or the tire sidewalls. Place the guage against that for your readings. I've got just about every attachment gizmo commonly sold and found that to be the best.
Old 06-21-2010, 09:00 PM
Poor-sha
Track Rat
Poor-sha's Avatar
If it's the Longacre digital one then you can buy just the tripod. The guage just has a threaded hole in it that should work with either.
I thought about a spacer - ideally something machined to the right size with the bolt coming out of it perfectly centered to screw the guage on. If someone comes out with something I'll buy one.
Old 06-21-2010, 09:05 PM
Everett Ogilvie
Speaking of adaptors, all the sellers of these gauges list a GM adaptor, stating it is 3/4-20. I don't think our spindles are 3/4-20......, so I wonder what this GM adaptor is?
Old 06-21-2010, 09:13 PM
davidfarmer
davidfarmer's Avatar
this is why I came up with my method.....
It is very very hard to settle the suspension, especially the front, fully with the wheels off. There is lateral 'stiction' in the front spring/control arm junction, and it takes a lot of jiggling to get it fully settled.
A camber gauge/angle gauge that you simply hold against the wheel is quicker and easier for me personally
Old 06-21-2010, 09:20 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
http://www.longacreracing.com/catalo...d=1301&catid=5 I have something like this and I believe it was Longacre but I don't remember it exactly like this. I have not seen it in a while.
Old 06-21-2010, 09:32 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Yup - that's what I use.
Old 06-21-2010, 09:36 PM
NMsharkracer
Everett, If you support on the ball joint then your spindle will turn freely. You'll need to maintain the approximate ride height.
Old 06-21-2010, 09:38 PM
JDIllon
JDIllon's Avatar
I use a 24" digital level from Sears and it works great and is dead accurate, and it has a laser in it also. Reads in 10ths of a degree and costs about $70.00 JD
Old 06-21-2010, 09:46 PM
dvandentop
dvandentop's Avatar
got the same one except shorter version
Old 06-21-2010, 09:51 PM
Everett Ogilvie
Thanks for all the replies!
Like trackboss suggested, one of my sets of wheels allows me to push the adaptor/gauge through the open spokes and stick it to the rotor, and it appears that will give a good solid mount and accurate readings. My track wheels won't let the gauge fit through, but I guess it does not matter what wheels are on the car when I measure.
P.S look out, cause next time I go to Track Attack I will have -8 degrees front and -3 degrees rear!
Old 06-21-2010, 11:56 PM
fatbillybob
fatbillybob's Avatar
I have thought about making a plate to bolt to the hub then ride on ball bearings to remove stichion. Then you could reach all the adjustment points and do suspensions really fast. I even thought about welding something to old brake rotors just to save me the fab time.
To Stupid question about camber gauge
Old 06-22-2010, 12:17 AM
thehammer69
thehammer69's Avatar
That 24" Digital Laser level at Sears is on sale this week for $40. Bought one Sunday to do my alignment.
Old 06-22-2010, 03:01 AM
trackboss
trackboss's Avatar
Many high end race teams build really trick hub stands that bolt in place of the wheel and make everything super easy including the actual adjustments.
Here are two that are really nice for off the shelf pieces. There are some things I wish they would make better, but for the most part they shold be a huge time saver.
http://mittlerbros.com/accu-lign.php
http://www.hubstands.com/
Old 06-22-2010, 03:35 PM
Gordy M
Gordy M's Avatar
I filed off about 1/32" at each of the three magnet and about 1/3" high. These would then fit inside the Z06 wheels. On the standard C5 wheels, they never did hit.
Quick Reply: Stupid question about camber gauge
