C6 Corvette Convertible Custom 4 Point Bolt on Roll Bar
Old 05-14-2010, 05:44 PM
bpproducts
bpproducts's Avatar
Default C6 Corvette Convertible Custom 4 Point Bolt on Roll Bar
Bolts on in less then 4 hours then hit the track and have fun. Been approved for NASA, ERME, PBOC and more.
Comes powder coated Black unless specified another color
( Extra cost my apply)
Part # 100-246 Convert $ 1599.00
http://www.breathlessperformance.com...onvertible.asp
Old 05-15-2010, 04:12 AM
Dave Deerson
Dave Deerson's Avatar
How can this be approved for NASA HPDE even when the belts attach at a single bolt/point?
Old 05-15-2010, 09:49 PM
bpproducts
bpproducts's Avatar
HPDE does not require a 5 or 6 point seat harness just the stock seat belts are fine. 5 or 6 points are required for the race classes. HPDE do require a roll bar. If you want you can use a single mount or just get a wrap around.
This bar will get you on the track.
http://forums.corvetteforum.com/c6-t...nvertible.html
Customer install link above
Ernie
BreathlessPerformance.com
Old 05-16-2010, 04:09 AM
2000BSME
2000BSME's Avatar
I wear a 6 pt belt system with my stock seats and my custom roll bar. My roll bar looks very similar to yours, but I think I used 2" tubing, whereas yours looks a tad smaller.
Old 05-19-2010, 03:53 PM
bpproducts
bpproducts's Avatar
This bar was made to be a quick install and not having to remove the fuel tanks, not affecting getting in and out of the car. Letting you take your convertible to the road track and have some fun. Getting away from those glue on hoops which do nothing for you. Is was designed to run HPDE events and not so much of drag racing.
Ernie
www.BreathlessPerformance.com
Old 06-03-2010, 01:36 PM
bpproducts
bpproducts's Avatar
These are in stock now!!
Ernie
Old 06-05-2010, 11:12 PM
aTX427
aTX427's Avatar
St. Jude Donor '09-'10
You can operate the top with the bar installed?
Old 06-05-2010, 11:51 PM
NTMD8R
NTMD8R's Avatar
Sure can
Old 09-20-2010, 03:10 PM
zmonster
zmonster's Avatar
What about the windscreen accessory? Can it still be attached with roll bar installed?
- Eric
To C6 Corvette Convertible Custom 4 Point Bolt on Roll Bar
Quick Reply: C6 Corvette Convertible Custom 4 Point Bolt on Roll Bar
