Looking for a wing for my '99 vert vette for looks/hpde
Considering either of these carbon fiber wings. I do HPDE's and I want to build a 'racer' or 'ricer' look to my vette. I've already got a cf hood with some vent holes, lemans style headlights, and keeping with the boy-racer look I want to go with a cf wing like:
or this:
Constructive input welcomed. I don't really care if you like what I'm doing with my corvette or not... I would like to hear what you think about the functionality of either of these wings, or if you have another suggestions, fire away.
one of these sits up about 8.5" and the other (mounted on the yellow car) is 11" high. I wonder about the interferrence with the rear view, and what effect the mounting height has on function.
thanks for input.
or this:
thanks for input.
I have a roll bar. **** a "top" for my vert. I know aerodynamics are probably **** on a topless vert, but a wing would have to help, wouldn't it?
So you think a deck wing is completely unacceptable?
I was actually considering hard mounting the rear deck and using it for the wing mount. The wing won't be generating more than a couple hundred pounds of force at the most, will it?
http://forums.corvetteforum.com/c6-z...ng-add-on.html
I guess I need to make a bunch of brackets and stuff and come out of the body work in the rear to have a 'proper' wing mount? Does anyone know where and what is available?
Location: If you don't weigh in you don't wrestle Road America
I know of several guys running the APR wing
http://www.aprperformance.com/index....d=34&Itemid=44
Yeah it's mounted to the deck lid but from the people using it they are happy with it.
They will block the rear veiw, the higher the better it will work, and I would not bother on a vert. unless it is for looks. I would put a spoiler on if any thing. JMHO
This isn't necessarily true. At some point you are creating too much of a Cd for a given level of downforce.
Like Tom mentioned, it takes a long time to set up aero for the best results.
2000BSME, do you plan any additional safety mods?
Mike
If you take decent proven parts it does not take all that long to set up as none of us or most have no access to wind tunnels and will never get to where a NASCAR tweaks to. My car worked great on day one a huge difference. I have tweaked a few things for better results after the first time out and continue to.
Wings do not need 4" splitters, extractor hoods, or side skirts to work. They all help in down-force but are not required. Many times 4" splitters are not even allowed in many race series they may even have to be flush with the nose of the car.
I completely agree there will be a noticeable difference immediately. There are tweaks you can perform to attain higher straight-a-way speeds without losing time in the twisties. A higher wing can prevent this (and possibly create more lift). I was very fortunate to have had Pratt and Miller help me with aero data and have many pro drivers dial it in afterwards.
As far as most people having no access to a wind tunnel, what I suggest is the following:
Find a nice high speed sweeping turn (with a lot of run-off ) and start dialing in more wing rake. As the car starts to push -- dial it back.
Mike
John,
Mike
Mike
I plan on putting in a few racing seats to better hold me, and to place me a tad lower in the car in case of a rollover, maybe my bar and my windshield frame will have a better chance of saving my spine from compression. With a vert, i'm required already to run a rollbar, arm restraints, 6 pt. harness and fire ext. I think I'm pretty well covered, except for seats to lower my position. Hans device is being considered too.
But I don't want to talk about safety in this thread.
I am aware of this, but am unsure as to what the height will do, of course I'm going to have a taller wing if it will help with visability. Thanks for the heads up. I plan on test fitting some 2x4's and cardboard to figure out what heights I can live with.
Just make sure you have proper support for your application. This will depend on how much downforce you dial in and where the wing attachement mounts are located. If you run low downforce levels of approx 200 lbs and the mounts are located toward the edge of the lid, your probably fine.
John,
Mike
Mike
I bumped mine up level with the roof may be a 2.5" rise from where it was. Hope to have time to put it together soon before I hit a nursing home instead of a wall!
Trunk lid mounting will flex and change AOA at speed which is critical.
Unlike an engine mods AERO work never blows up and it also helps on deceleration!
I find it very rewarding. I played the game years ago on bikes in 1975 by having a street bike with a full race fairing long, long before any sport bikes were thought of. It was a 15 mph gain and back in 1975 a bike running 175 MPH was real fast.
I am selling a C5R Wing I had on my C5 coup. Send me an email and I will send you a photo if you are interested. bhalford@pathtechltd.com
