Stupid Brake Fluid Question?
Old 04-27-2010, 02:13 PM
k0bun
k0bun's Avatar
Location: NJ..."the way I saw it, everyone takes a beating sometimes."
Default Stupid Brake Fluid Question?
If I siphon (turkey baster) out the brake fluid from the master cylinder and then refill it with new fluid, do I still have to bleed the brakes? I'm curious what's done in between laps during HPDEs. Obviously this wont be a very thorough flush, but I figure it might help a little and save time, assuming you don't still have to bleed the brakes anyway.
School the ignorant please. :o
Old 04-27-2010, 02:41 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Yes you need to bleed. The new brake fluid will not make it to the calipers without bleeding. New brake fluid should easily last a day for HPDE. At the end of the day you can bleed off at the calipers if you want but chances are for a single day event you will not have to.
Old 04-27-2010, 02:54 PM
k0bun
k0bun's Avatar
Thanks Bob. Do you think I'll be alright with the 30k mile, 3 1/2 year old, stock brake fluid? Trying to get everything ready for Monticello next week but not going crazy because I doubt I'll be doing anything the car can't handle. Just routine maintenance really. Oil, trans, dif, clutch, and PS fluids have all been changed/flushed. I was holding off on the brake fluid (no good reason other than probably just being lazy) and the coolant. Even though the brake fluid is probably the first thing I should do for a HPDE.
Old 04-27-2010, 03:03 PM
QSZOH6
QSZOH6's Avatar
Brake fluid flush should be pri 1. Flush with a new bottle of DOT4. You will see the fluid that comes out of the calipers and you will be glad you did.
Old 04-27-2010, 03:06 PM
k0bun
k0bun's Avatar
Yeah my Motive Power Bleeder just arrived so I'll change it this week.
Thanks guys
Old 04-27-2010, 03:08 PM
johninar
johninar's Avatar
As was said above. If you are new to HPDE you will be hard on your brakes.
Make sure you bleed AFTER as well. That fluid will have been hot.
Stay safe, have fun, and keep your head screwed on straight!
Old 04-27-2010, 03:16 PM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
on the DOT4 recommendation. Tire Rack sells ATE fluid in both blue & amber. I know a lot of folks are fans of Motul and I'm sure it's great stuff, but the different colors are a VERY easy way to tell when you've gotten the old fluid out(maybe Motul comes in the colors too, I don't know). Just alternate from one color to the other on bleeds.
Old 04-27-2010, 03:19 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If you saw the nasty bottle of crap I flushed out of the wife's daily driver after 3 years you'd be saying to yourself "Hey - did you flush the brake fluid this year???"
Cereal - if your brake fluid is more than a year old - flush it before going to the track.
Old 04-27-2010, 04:36 PM
k0bun
k0bun's Avatar
Thanks everyone. I have a few extra bottles of Prestone DOT4 I just picked up for the clutch so I'll use that for the brakes too. And my MPB just arrived so I think I'll head to the garage and get messy.
Old 04-27-2010, 06:45 PM
davidfarmer
davidfarmer's Avatar
Prestone or Valvoline Dot 4 Synthetics are more than adequate..........
Old 04-27-2010, 07:38 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Would you go mountain climbing with an old rope? 3.5 years old is old rope!
Old 04-27-2010, 09:40 PM
punz
punz's Avatar
St. Jude Donor '12-'13-'14-'15
I thought synthetics for the brakes in our cars are not to be used?
Old 04-27-2010, 09:56 PM
lbs90ZR
lbs90ZR's Avatar
Dot 4 Synthetic is ok. Dot 5 Silicone is not supposed to be used in ABS brake systems.
Old 04-27-2010, 10:14 PM
rfn026
rfn026's Avatar
Here's a lot of information about brake fluid. Also, I believe in changing it before every event. My last event at Homestead was rather amusing - if not dangerous. I lost my brakes loading the car on the trailer.
My crew had the ramps down and I thought it would be nice to just drive off the track and right up on the trailer. I forgot to drive around the pits for a little bit to let everything cool down. The brake fluid heat-soaked and boiled as I was carefully going up the ramps. A moment of panic. Nothing happened so no harm no foul.
Everything cooled off in about 2 minutes and all was fine.
Richard Newton
My Speed Blog
Old 04-27-2010, 11:57 PM
k0bun
k0bun's Avatar
I wouldn't go mountian climbing.
I agree that's why I put the little rolley eye guy there. I was just too lazy to do it today with all the other fluid swaps. Then my MPB came and I got my second wind. All changed.
To Stupid Brake Fluid Question?
Quick Reply: Stupid Brake Fluid Question?
