Which tires ?
Old 04-24-2010, 08:17 PM
blkz
blkz's Avatar
Default Which tires ?
Can someone comment on the following for roadcourse use . Kumho Ecsta V710 , Toyo R888 , Hoosier R6 . Thanks .
Old 04-24-2010, 08:22 PM
longdaddy
longdaddy's Avatar
hoosier or kumhos are similar. r888 is a treaded tire that will last a little longer at the expense of max traction and can be used as track/street/rain tire, the other two are dry track use only and will not last as long.
any one of these is a good option for roadcourse assuming you have already found the limits of street tires. what are you specific goals? dual use? price efficiency? max performance?
Old 04-25-2010, 12:37 AM
0Finspeed
Former Vendor
Finspeed's Avatar
If you are looking for a track only tire, you might want to consider these:
I am at $1576 shipped, for a set of 30/65 and 31/71's (fronts and rears).
http://finspeed.com/Michelin-Racing-Slicks-MCH.htm
BTW, they are the fastest tire out there.
Let me know if I can help.
Daniel
http://finspeed.com
To Which tires ?
Quick Reply: Which tires ?
