Tool sizes for brake pad replacement
Old 04-19-2010, 05:33 PM
Dan Wendling
Dan Wendling's Avatar
Default Tool sizes for brake pad replacement
What are the correct tool sizes for 2010 Z06 brake pad replacement?
Caliper bolts (6 point ?? mm)
Brake Pad Pins (Torx ??)
Do I need some type piston compressor tool? Have never seen one for 6 pistons!
I am replacing 1 piece pads from Carbotech, so I need to remove the calipers.
Old 04-19-2010, 06:25 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Pretty sure it's a 21mm, same as a C5.
Old 04-19-2010, 07:13 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
21mm socket. Pull the caliper off of the upright and do NOT remove the pins from the caliper.
Remember red locktite on the bolts when they go back in. I believe it is either a 10mm or 11mm wrench for the bleeder screw.
Old 04-19-2010, 08:52 PM
bluemagoo
bluemagoo's Avatar
caliper bolts = 21 mm
pad pins = T-45 torx
bleeders = 10 mm
To Tool sizes for brake pad replacement
Quick Reply: Tool sizes for brake pad replacement
