C6Z Front Shim affect on camber?
Old 04-17-2010, 07:49 PM
H1ghlndr
H1ghlndr's Avatar
Default C6Z Front Shim affect on camber?
Does anyone know approximately how much camber each shim is worth on the top control arm? I am removing some for more camber.
Thanks in advance.
Bob
Old 04-17-2010, 08:47 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I think each shim is approx 1/2º, assuming you remove one from each bolt. I'm pretty sure I took 2 from each arm and went from -1.2 to -2.2, then later put a thin shim back in to get down to -2.0.
Someone else had a post on this more recently and may correct me if I'm wrong. btw, be carefull with the threads in the frame. If you damage them, you will regret it.
Old 04-17-2010, 09:09 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
I agree. I usually take two out to go from -1.4 to -2.3. Last night I took an extra one out to get to -2.8. I'm not sure if my washers are the same thickness as the factory ones since I'm running a camber kit.
BTW, I reset the toe but as long as I am removing an equal number of shims from each stud should it affect the caster?
Old 04-17-2010, 11:30 PM
davidfarmer
no, as long as you remove the same number from all 4 bolts, the upper balljoint does not move fore/aft relative to the lower ball joint, so the castor does not change.
Old 04-19-2010, 06:31 PM
H1ghlndr
H1ghlndr's Avatar
Thanks Guys! I took out 2 and now it's off to the alignment shop for my track alignment.
Thanks again,
Bob
Old 04-19-2010, 06:44 PM
C5Lion
C5Lion's Avatar
I think it is actually about 0.4 degrees per washer.
Old 04-19-2010, 07:53 PM
dbratten
dbratten's Avatar
Default Washers
A word of caution -- I mic-ed a handful of hardware store washers and their thickness varied by quite a bit. If you're trying to be precise check the ones you're using.
--Dan
Old 04-19-2010, 08:45 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
--Dan
the average washer is made from scrap and that is why the vary. If you want consistent thickness buy graded washers like graded bolts.
Old 04-19-2010, 11:25 PM
dbratten
dbratten's Avatar
Right, but as I only use washers to set caster or compensate for L/R differences I can fine tune it better with the varying thicknesses and then use a set number of shims to add and remove camber as needed.
Old 04-19-2010, 11:56 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Randy
To C6Z Front Shim affect on camber?
Quick Reply: C6Z Front Shim affect on camber?
