Fuel/turn issue
Fuel/turn issue
My 96 lt4 need to have more than a half tank of gas to avoid it cutting out on the track.
The problem occurs especially in fast sudden turns.
Is this normal on C4´s used at track days? What can be done, other than making sure you start out with a full tank..?
Normal C4 feature
If it really bugs you then you need to make a collection tank which will always have fuel and never starve. We did that in offshore race boats.
I have never had the problem on the street either, but when you really push the car on the track it will cutout with below about 1/2 tank on gauge.
Location: If you don't weigh in you don't wrestle Road America
It's not a tough fix, all you have to do is take the fuel pump assembly out of the tank.
Look down in the tank and you will see a little plastic tray, it's there to keep fuel in it while cornering, etc. When they installed the fuel pump assemblies they didn't bend the tubes down far enough to be completly inside the tray. All you have to do is bend it down a bit and you're problem is gone.
I used to have problems when I had anything just under 1/4 tank. Now I can run the car down to reserve at the track before it acts up.
Do a search in C4 tech they probably have a thread with pictures. Not tough though.
Same thing I did.
Also clean the fuel level wires while you're there. And it may need a new seal around the tank. You could put some fuel cell foam in there too.
