07Z06 Track car - Chassis/Suspension greeze points
Over the past month the squeeks and groans from below have become unbearable.
I suspect either the shocks (new pfadt units just 3,000km past), or the stock chassis/suspension
I use the car in 30deg C+ heat and for track use, so the joints get a real pounding
What goes first? Where should I look? What is going to fail?
Thanks for your input
John
John
Before you do anything, make sure it's not the exhaust hanger springs (holding the exhaust up at the mid-section of the car). Go shake the exhaust up and down and see if that's the squeak. Mine were squeaking pretty bad when I went over any sort of bump. I just greased them and put a small rolled up piece of thermal tape inside them to add some damping (don't know how long this will last, but it fixed the problem).
The main creaking that I've gotten from these cars is the swaybars in the bushings that attach to the carrier. Disconnect the ends and slide the bar to one side, put some grease on the bar right by each of the bushings, and then slide it back and repeat on the other side. Slide it back and forth until there is lots of grease inside the bushings and then re-attach the ends. Wipe off the excess and you should be less creaky.
I'm afraid so. Had already done that before I asked.
The exhaust was my first bet, so I welded it up, but made no fifference
I suspect the shocks, but I dont know how to do anything about it
John
John
Here's a link showing what you're looking for. These grease fittings are not found on the non-Z51 base Corvette.
http://www.nakidparts.com/id47.html
