Engine building service available
Old 03-14-2010, 03:00 PM
jfaphoenix32
Supporting Vendor
jfaphoenix32's Avatar
Default Engine building service available
Phoenix Performance has opened its in house engine building services division.
Specialties include building and rebuilding of all GM LS engines, including LS1, LS2, LS3, LS6, LS7 and LS9... Plus all of the older Chevy Shortblocks, short rack and carbeurated engines.
Capabilities include full machine shop expertise, including CBN Cutter technology to quickway boring and honing, sunnen rod reconditioning, heinz balancing and crank shaft grinding.
Full assembly and blueprinting available by engine specailist with over 25 years hands on experience...
All work is custom done to customers specs.
Call for information and to discuss your personal requirements...
610-482-0141 jfaphoenix32@aol.com
Old 03-27-2010, 07:26 AM
jfaphoenix32
Supporting Vendor
First two orders for ls3's in the books...
Call if you want to discuss your project. Will rebuild ls6's and Ls1's, as well as upgrade heads and cam packages...
Install service available also...Along with suspension and track day setups...
call Joe 610-482-0141
Old 04-14-2010, 07:16 AM
jfaphoenix32
Supporting Vendor
to the top
Old 05-08-2010, 08:04 AM
jfaphoenix32
Supporting Vendor
Thanks for all of the calls... We have 4 ls engines underway and can do more, so if you need some help, just call.
610-482-0141
Old 05-21-2010, 04:52 PM
jfaphoenix32
Supporting Vendor
to the top.
Old 06-27-2010, 12:46 AM
jfaphoenix32
Supporting Vendor
call with any questions... All work is guaranteed...
we also do removal and installation, as well as custom tuning...
610-482-0141
Old 06-30-2010, 07:44 AM
jfaphoenix32
Supporting Vendor
cylinder head resurfacing also...
Old 07-06-2010, 06:59 AM
jfaphoenix32
Supporting Vendor
Specializing in Corvette engines from all generations... Over 30 years experience.
Old 07-15-2010, 06:54 AM
jfaphoenix32
Supporting Vendor
to the top.
Old 09-23-2010, 07:43 AM
jfaphoenix32
Supporting Vendor
Taking Orders for the early winter delivery...Call 610-482-0141 if you have questions...
Joe
Old 10-05-2010, 06:30 AM
jfaphoenix32
Supporting Vendor
to the top.
Old 10-05-2010, 01:01 PM
TedDBere
TedDBere's Avatar
Joe/Steve: What's the manufacturer's first standard overbore for an LS6? And what would you guys charge to do it? Everything stock for SCCA stock classes.
Old 10-05-2010, 08:04 PM
jfaphoenix32
Supporting Vendor
pm sent.
Old 10-06-2010, 10:19 AM
TedDBere
TedDBere's Avatar
Originally Posted by jfaphoenix32
pm sent.
Not received.
To Engine building service available
Quick Reply: Engine building service available
