T1 bars, are they worth keeping?
Old 03-11-2010, 08:02 PM
69dodgecharger
69dodgecharger's Avatar
Default T1 bars, are they worth keeping?
Hey,
So I currently have T1 sway bars on my zo6 w/ the 02-up endlinks and phadt coilovers. Are these swaybars really worth anything on my car? Asking because I am thinking about selling off useless mods so I can finish up my Charger project.
Would I notice a big difference with a set of stock Z bars?
Thanks!
Old 03-11-2010, 08:27 PM
UstaB-GS549
UstaB-GS549's Avatar
I don't think you would notice the difference on the street. My thinking is that you might be better off selling them and putting car back to stock.
Old 03-11-2010, 08:48 PM
tomiboy
tomiboy's Avatar
How much do you want to get for the T1 sways? Will they fit an 09 Z51 coupe?
Old 03-11-2010, 08:49 PM
rustyguns
rustyguns's Avatar
Originally Posted by 69dodgecharger
Hey,
Thanks!
you only need those T1's if your running slicks
Old 03-11-2010, 08:56 PM
gkmccready
gkmccready's Avatar
Probably need a muffler change on a C6 unless they're the new style bar.
The Pfadt coilovers run a pretty soft spring rate similar to what my DRMs have -- when I added bigger bars (old style Pfadt comp bars) it made the car quite a it more fun to drive and easier to push on the on-ramps, etc, so I actually think the larger bars combined with the softer springs work pretty darn well. I do, however, run Toyo R888s -- even on the street.
Old 03-11-2010, 09:05 PM
69dodgecharger
I run RA1's so its comparable. Just trying to get some opinions. I know a couple people who run auto-x with r888's and no rear bar and do fine so I'm thinking stock bars on the street would still be fun.
Old 03-12-2010, 01:11 PM
gkmccready
gkmccready's Avatar
Hey, you asked for an opinion. :-)
The guys running no rear bar are probably ASP cars running a big front bar, and high rate leaf springs. The big springs and the fact the leafs tie things together side-to-side will help them there.
You'll probably get about $500 for the T1 bars, and it'll cost you about $200 to get C5Z bars from a dealer or Gene Culley @ GM Parts House. Is $300 worth going back to a bunch more body roll? Your call. I'm happy I put on the bigger bars, even on the street.
To T1 bars, are they worth keeping?
Quick Reply: T1 bars, are they worth keeping?
