Corner Balancing
Corner Balancing
Anyone perform this on a C6 Z? Looking for tips and advice. First time getting it on the scales. Running Pfat coilovers.
Have the car full of fuel, that's repeatable if you do this again. Make sure the scales are level. You will need to roll the car off, and back on the scales after you make an adjustment. Set the tire pressure. Have the driver with all his/her gear in the driver side seat. Disconnect one end of each bar. Use the wheels and tires you will be racing with.
