PCM Relocation Pictures?
What tank are you using? I'd think that you don't have a whole lot of options for moving it as it has connections directly to the under hood fuse box and the TAC. If maybe you moved the wiring harness towards the fuse box you could move the PCM a little closer to the wheel well, but that is just guessing based upon some wiring work I did.
St. Jude Donor '05-'08
I can take pictures, but I found this one I already posted. Not that close up, but you get the idea (actually a new picture might be in order since we now have it mounted in a box). I used the LPE relocation kit to relocate the battery to the trunk.
Bob,
Thanks for the note.
I have my battery in the same Lingenfelter box in my trunk.
If you get a chance and can take a closeup of your PCM from the top, so I can see what you have done in relocating it.
