C5 Front Upper Ball Joint Taper?
Old 03-02-2010, 02:52 PM
gtpvette
gtpvette's Avatar
Default C5 Front Upper Ball Joint Taper?
I need to verify the taper in the front upper a-arm for the ball joint. Eveything I can find says 1 1/2" taper per foot or 7 degrees.
Correct?
Thanks!
Old 03-02-2010, 05:32 PM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
According to my CAD data it is a 4.68 degree (call it 5) which works out to a 0.9818" per foot (close to 1"). This is measuring the upper ball joint stud.
Quick Reply: C5 Front Upper Ball Joint Taper?
