18x12 F, 18x14 R?
Hi again! No they won't. 11.5 with the right back set will barely miss the DRM coolers by 1/8", 13's will fit the rear with L5 fenders. With stock fenders, 315's are the largest tire with 12's. I run 335's with the L5 fenders.
I hope that helps.
D.J. Covert
I hope that helps.
D.J. Covert
I knew they wouldn't but I've been frothing at the mouth over a set on that auction site. Guy has a brand new set of Kodiaks in these sizes with a buy it now price of $1500.
It's just as well they won't cause I can't afford them but if they were the right size I might do something stupid and buy them anyway.
Thanks for the reply!
^^He has the L5 wider fenders. I am puttin on TPE T2 fenders that are 2" wider. You can fit 18X335's on a 12" rim on the rear with stock Z06 spacing but they will rub on the inside a bit. They eventually will just rub out a grove in the inner fender and be fine but they will stick out of the fender a decent bit too without a wider fender.
