FS: Brey Krasue harness bar for C5
Old 02-27-2010, 05:21 PM
The Spark
The Spark's Avatar
Default FS: Brey Krasue harness bar for C5
Selling Brey Krause harness bar for a C5. SOLD
This is the harness bar only. No harnesses. No lap belt mounts.
Bar is in good shape. I did have to grind a corner off one of the upright supports to fit my seat bracket - but it should not affect the bar at all.
There are a few small chips in the paint on the passenger side where the harnesses go on the bar.
Old 02-28-2010, 12:21 AM
PaConehead
PaConehead's Avatar
Does this include the required mounting hardware, or does it reuse the original hardware?
Will this fit a C5 Z-06? Thanks
Old 02-28-2010, 08:02 AM
The Spark
The Spark's Avatar
It does come with the hardware. You replace the bolt for the upper shoulder belt with a longer one. It allows you to install your OEM shoulder belt with the harness bar so you can retain your stock seat belts. There are also 2 bolts that attach the uprights to the bar. The bottom of the uprights attach to the outside bolts of your rear seat track.
You reuse the nut on your factory seat mounting. Installation is pretty simple. Remove the rear outside nut on your seat mount. Slip the uprights in position.
Brey Krause website says it will fit all C5 coupes and fixed roof coupes (Z06).
Here is their website. There is a link to an installation article.
http://www.bkauto.com/corvette/r1115.php
Old 03-01-2010, 12:54 PM
The Spark
The Spark's Avatar
ttt
Listed on ebay last night.
Still time to purchase.
Old 03-05-2010, 08:55 PM
The Spark
The Spark's Avatar
ttt
ebay auction ends Sunday. Several watchers. if you're interested don't wait.
To FS: Brey Krasue harness bar for C5
Quick Reply: FS: Brey Krasue harness bar for C5
