how much tread depth are slicks when new?
anyone have any idea how much if you would measure do new slicks come new?? specifically Michelin slicks?
thanks alot
looking at buying some used Michelin and just trying to gauge how much is left on them
thanks
thanks alot
thanks
These measurements were taken off very slightly used scrubs; I tried to be careful not measuring an area with rubber build up so take that for what it is worth:
The Yokohama Advan slick in a 280/680-18 measures 6/32 nd's from the surface to the bottom of the wear dot. By the way, I just ran these yesterday at Laguna Seca and they are very progressive with an excellent feel, very good traction because of the tall section width. They wear like iron, if the 24 hours of LeMans ever implemented a no tire change rule, these would be on the winning car. Slower than Dunlops and Hoosier R100's. Low pressure, 28 psi hot.
The Hoosier R100's in a 305/650-18's measure 5/32 nd's to the bottom of the wear groove.
you need to measure the hardness with a durometer, but to make sense of it you need to know the hardness when new and the hardness when they are junk. this is also complicated by the fact that taking durometer measurements is not a hard and fast science.
scrubs are worth very little in general, and you should pay accordingly!
I think it was 3/32 to the cords but you may be right also Tom. It is on the hoosier web site some where. I do know one thing for sure it isn't much!
I could not find it. It may be on GY site or have dissappeared.
Fair warning below
Application/Misuse: All Hoosier Racing Tire products are designed for a specific purpose. Consult with Hoosier Racing Tire Corp. for specific fitment and application. Utilizing Hoosier Tires in any form outside of their intended use constitutes misuse of the product and can cause SERIOUS PERSONAL INJURY OR DEATH. Hoosier Racing Tire products are designed and manufactured for racing purposes only, within a closed course designed for organized competition. Not for recreational use. Hoosier Tires should never be used for Off Track Exhibition or for Land Speed Record Vehicles including Jet or Rocket Powered Cars.
Fair warning below
