Tool used to push pins out on top of BBK Calipers
pins on top of caliper that hold the pads in place.
I did a search, but am not finding the tool used to push these pins out with to swap the pads
I've not used those, but Stoptechs are actually long bolts that thread in. I'd make sure there isn't a bolt head hidden down inside, and if not, contact AP or the seller. If you have to press them out, that sounds like a pain in a rush (almost C6Z06 bad)
Get yourself a set of drifts / pin punches....you'll use them all the time.
http://www.harborfreight.com/cpi/cta...emnumber=93460
Location: If you don't weigh in you don't wrestle Road America
The CTS-V Brembo's us the same system and I just use a punch, then tap them back into place when finished. I actually like them better than the StopTech / Wilwood calipers with bolts.
Either system is just as easy to maintain, IMHO.
If rigidity increases brake feel then the price/performance for the stoptechs is perhaps unbeatable.
