Anyone running 15w-50?
Old 08-08-2009, 04:05 PM
02impactblue
02impactblue's Avatar
Default Anyone running 15w-50?
I have been running 10w-30 in my track car but have seen oil temps hitting 280 in the heat of the summer. The car has a Dewitts Radiator with integrated oil cooler. I was thinking of switching to 10w-40 or 15w-50 for track use. I realize it wont help reduce my temps but the thinning out wont be as severe on the heavier oils. Is 15w-50 too heavy for a stock LS6 motor? Thoughts?
Old 08-08-2009, 04:48 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I run it
Old 08-08-2009, 05:07 PM
rfn026
rfn026's Avatar
I run 0-30w at the track. It helps keep my temps down. Both of the oil companies that I've worked with over the past few years are believers in thin oils. They keep reminding me that "Richard - it's not 1966."
Richard Newton
Old 08-08-2009, 05:19 PM
AU N EGL
AU N EGL's Avatar
with oil cooler dont see oil temps above 240 now
Old 08-08-2009, 05:54 PM
sperkins
sperkins's Avatar
Originally Posted by drivinhard
I run it
Me too.
Old 08-08-2009, 06:49 PM
argonaut
argonaut's Avatar
Originally Posted by sperkins
Me too.
+1 more - 15W50 Amesoil
Old 08-08-2009, 08:05 PM
waddisme
waddisme's Avatar
After talking to subdriver, I went with their Premium 20-50. He says it has more detergents as my car is also a daily driver. Also, they are having an awesome sale on Amsoil right now.
Old 08-08-2009, 08:26 PM
Bimota Guy
Bimota Guy's Avatar
Yes...Mobil 1 in the race car.
Old 08-08-2009, 08:42 PM
mgarfias
mgarfias's Avatar
What he said. Works great.
Old 08-08-2009, 08:49 PM
rustyguns
rustyguns's Avatar
yup! 15-50 in the Ls6 good stuff if your temps are gettin' close to 300. 30 does very little above 275
lighter does give a a tad more hp
Old 08-08-2009, 09:17 PM
Exotica
Exotica's Avatar
I run it.
Old 08-08-2009, 10:04 PM
johninar
johninar's Avatar
me too
Old 08-09-2009, 12:04 PM
fatbillybob
fatbillybob's Avatar
Richard Newton
And modern syn oils can take around 400-500 degrees before breakdown iirc.
Old 08-09-2009, 04:48 PM
wmckeenster
wmckeenster's Avatar
15-50 is all I use
Old 08-09-2009, 04:55 PM
02impactblue
sounds like many track cars are running the 15w-50. I just bought 2 5qt jugs at Walmart and will give it a try.
Old 08-09-2009, 05:24 PM
gkmccready
gkmccready's Avatar
I just ended up grabbing 10w30 Redline just now; I was aiming for 10w40 but they didn't have enough in stock. And they didn't have the 15w50, either. Jumped straight to 20w50.
The Redline website said 15w50 wasn't recommended for engines that saw any significant time below 200F oil temps and if that was the case using 10w30 or 10w40 would be better. Since I was buying all the fluids to swap in a DRM Ron Davis radiator/EOC/TOC combo and I don't know where the oil temps will be for the daily drive aspect the 15w50 seemed too much for me.
Old 08-09-2009, 06:26 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
yea but the engine can't
Old 08-09-2009, 06:37 PM
02impactblue
I was aiming for 10w-40 as well but the only thing I could find was "10w-40 High Mileage" recommended for engines with 75k+ miles. Does anyone know what the difference would be for regular and high mileage oils?
To Anyone running 15w-50?
Quick Reply: Anyone running 15w-50?
