Helmet trim glue??
Old 08-04-2009, 07:32 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default Helmet trim glue??
so between having a new paint job, and having radio's mounted, the trim on the bottom of my helmets always falls off. Anybody know that they use??? Feels like it's probably from a hot glue gun.
Any suggestions?
Old 08-04-2009, 02:10 PM
leaftye
leaftye's Avatar
I've been told motorcycle helmets use hot glue. My guess is that your guess is correct.
Old 08-04-2009, 07:22 PM
steponc
steponc's Avatar
St. Jude Donor '14
I have always had good luck with Barge Cement. It is a contact glue that you put on both surfaces, wait until they are no longer tacky, then place them together.
My original source was our local saddle maker. He used it for leather to leather. I have used it for auto trim pieces that have come loose and for shoe repair, rubber to leather or cloth.
If you can't find an outlet for it, let me know and I'll send you a tube.
I buy mine at our lumber yard/ hardware store in the glue section with the Gorilla glue, J B Weld and so on.
Old 08-04-2009, 09:35 PM
davidfarmer
thanks. My problem with the hot-glue is that it is very hard when it cools. Once it loses it's mechanical grip, it just leave the hard residue behind. The Barge cement sounds worth trying. Looks like it's readily available online if I can't find it locally.
Thanks again!
Old 08-04-2009, 10:03 PM
JDIllon
JDIllon's Avatar
Dave, I think any good contact cement will work fine. You can buy either spay on and brush on. Just my .02 JD
To Helmet trim glue??
Quick Reply: Helmet trim glue??
