Anyone ever make?
I just did it using the car. I strapped the car down on the lift, put my digital scale underneath, and used a 4x4 to connect the two. Measure deflection vs load at several loads, then average them out. Of course you need to correct actual rate vs wheel rate to have a usefull measurement.
I started just using the weight of the car, but found I needed some weight and/or straps to pull down to get adequate deflection. You need a reliable point of reference for your measurements also, but it's not hard.
1 Post
Cruise-In II Veteran
That is a really good idea because how you mount and load it is critical to getting accurate results. On each side, the spring is a cantilever beam and the deflection goes as the length cubed! So if the spring is say 20 inches long, a 1/4 inch difference in where the load goes equates to almost 4% difference. So, judging from your previous posts, if you are trying to see a degradation in rate over time, 4% error or scatter in the data, is very relevant. So, just do whatever you decide to do the same way every time. It would be very interesting to see how much the opposite side moves as well when you load the spring to confirm/deny the leaf spring "crosstalk" theory.
Former Vendor
The funny thing is I was just thinking about doing this again. We have a chassis on the lay out table and I'm going to have my suspension apart, and have some pin top testing that should be done. Now with video cameras, digital cameras and etc this would be a good thing to show the forum. We have done it in the past but for our own good.
During the Corvette challenge we tested hundreds of springs.
We know the answers, but that doesn't work anymore. Now we have to show the customers more to make a few sales....
Crosstalk is one of things on the list of things to test again.
Now how to find more time in the day....
Randy
Randy
Randy
Randy
