Data Recorder with GPS Recomendation
I am thinking of buying a data recorder with GPS so I could use some recomendations.
One question I have how does the GPS work does it create the track you are on or do you have to download tracks and it identifies where you are.
An thoughts on how much it will help with autocross I do several autocross events a year and about 5 to 8 HPDE events which is the main reason I am buying one. Eventually I would like to try sonme Time Attack events if I can get fast enough.
We use the RACEPAK G2X GPS system. No beacon to forget at the track. Builds its own track maps but has a forum where you can download maps too. Integrated video in the software and you can export to TRACKVISION if you buy their software. Lots of sensors you can add. If you have a C6, you can plug directly into your service port to collect real time data on your existing stock sensors (C5 can't do that as its a different bus speed).
Check www.racepak.com and look at their forums........lots of good info. Or you can call/email tim @ racepak.com
Thanks for the information I called them today they were helpful. I am still investigating other options if anyone else has any recomendations.
I am wondering which of these options data logging or video capture improve performance more for someone just begining?
I don't know if it helps right off the bat. I think it could, so long as you have a good coach. I think consistency is the important thing early on. If you get that, lot of other things become possible. For example, without consistent lap times, you will not be able to accurately look at tire temps. Without consistent laps, you can't develop the cadence of the track.
I've got a Traqmate. Their software lets you display a huge number of parameters on your computer to analyze your track sessions.
Here's a screenshot of a session at VIR and you can see I've got a graph partially covering up the track map, but the graph is displaying speed, RPM, and throttle position:
If you have video, Traqmate has a software (TraqStudio) that integrates and synchronizes your video and data like you see below:
You can also have the software write a video file with the "dashboard" overlaid on the video like you see in the video below of Sebring:
There's software by TrackVision that will put the dashboard on video using data from many different data-loggers, but the way Traqmate integrates the data and video on your computer really gives you a great analysis tool.
Some of the other data-loggers mentioned just plug into the OBD port to gather sensor data for info about oil tem, oil press, coolant temp, etc. With Traqmate, you have to splice into the wire coming from those sensors and run it to your Traqmate, so it's not as easy to get that kind of info as it would be just plugging into the OBD port.
Bob
Bob
A buddy of mine has some videos of the software running here:
http://www.youtube.com/watch?v=hdNZwzFYOBQ
http://www.youtube.com/watch?v=8kntkJg5gck
All of the track maps are generated automatically using GPS data.
MaxQ feeds TrackVision as well so you can combine it with video. I have several examples here: http://www.youtube.com/bertschmitz
Although the videos are flashy, the actual learning comes from comparing two different laps. You can try different things on the course and see how that affects lap times. Or if you can datalog a faster driver, you can see what they are doing to make them quicker.
The MaxQ is entirely portable so it is easy to drop into other cars to collect data from different drivers and compare to your own.
Bert
Does anyone make a unit that taps into OBDII for a C5 generation computer (2004 Z06)? Or is the only option splicing into all the various sensor wires?
http://forums.corvetteforum.com/auto...a-systems.html
With regards to splicing into existing sensor wires, my impression is that on some sensors that is ok to do, but on others, it will change the output of the sensor too much. I don't know if this is true or if things are being blown out of proportion, ie, does a sensor being 1 degF off really matter? I've heard of people tapping into the throttle position sensor as is shown above. I'd sure like to know which sensors are ok to splice.
race-keeper sells a unit with an OBDII adapter. No splicing. It just plugs into your OBDII port and right into their unit.
PM me for a coupon code to get a free extra camera.
Thanks for the reply - looks like a nice unit. I suppose the question is whether my ECU (speed) is acceptable to provide an adequate data stream. I will definitely keep this unit in mind, thanks again.
Thanks again for all the great information.
I can see having these units is a good way to look at a track session in much more detail instead of just looking at times. I can also appreciate having a coach is another inmportant key to consitancy and better sessions.
