Water Wetter does it help and how did you use it?
I read the bottle and the directions were to add to your normal coolant mixture to lower temps. Has anyone done this, how much did you add, and what effect did it have?
The whole bottle. Dependent on the car it may help it cool better. It reduces surface tension and helps the coolant make better contact with parts of the system. This makes for better heat transfer.
drain the radiator, add Water Wetter, refill fwith plain water.
Repeat but put antifreeze back in before Winter.
If you just drain the radiator, you only get about 1/2 the coolant out, which gives you some benefit of WaterWetter but also keeps some of the benefits of anti-freeze.
I'm not sure that I trust Water Wetter's lubricating properties so I'm currently on 25% dexcool and one bottle of WW.
I haven't got the thing onto a track since doing this so I can't comment on the difference, but ECTs did seem a little
lower in street driving.
fwiw, this guy spent some time looking into the WW chemistry and came up with a thumbs-down: http://www.wizdforums.co.uk/showthread.php?t=2338
I believe in it. My car is a 1994 C4, 383 autocross car. We had two drivers at a poorly attended event, maybe 16 drivers so we were running pretty much non-stop and we didn't have time to shut the car off between runs. 94 degree day in FL. Highest temp was 182. Fans brought it back down to 172 almost immediately.
4 bottles of WW and the rest Prestone premix.
Far too many people have tested it and showed results for anyone to doubt it. It works different car to car but it does work. I worked at a race school for a while and we ran water and WW, that's it. The cars had 13b rotaries in them which make lot's of heat. The water pumps almost NEVER died. They would outlast multiple motors.
I have been told that WW is nothing much more than soap but I'm not a chemist so whatever.
I've used a similar product in my 67 GTO and saw no difference in temperatures. I used strictly water to the WW product, in the ratios recommended. One thing I noticed after about 4 months was a lot of corrosion in the neck/cap area of my Be Cool radiator. I started to wonder what the inside of the radiator was doing as well. I drained the stuff out and went back to a 50/50 mix of water and antifreeze. The car runs hot but doesn't overheat unless I really push it hard. The WW never brought the temps down, and the cool down took just as long. Sorry, not a believer of these products.
Former Vendor
Water Wetter does lube the water pump as does standard antifreeze.
Antifreeze will not keep a car as cool as distilled water.
Tap water will leave residue in a cooling system.
If a car is never exposed to freezing conditions then a combination of some sort of water pump lube and distilled water is best to keep the car as cool as possible.
The next year I dropped the mix level down to 10% antifreeze, used fresh distilled water and did a race. The very next day's race I added the water wetter and just as before, saw no difference in coolant temps.
Waste your money if you want.
I tried it at Savannah one year by just adding it to the mix (probably 30% antifreeze) and didn't see any temp differences at all.
you run anti-freeze at the track?
Former Vendor
Thats how I was first introduced to the product. It was probably mid to late '90s or so, when I was still doing motorcycle track events and they called it by name in the supps, that either straight water, or water and Water Wetter could be used, but no antifreeze was allowed.
There's nothing wrong with that. Since I race all year round, and the temp sometimes drops into the single digits at night (like December, January, Feb), I keep about 10-15% of antifreeze in there. It keeps everything lubed up in there and the block from cracking (or freeze plugs popping out). I also still drive the car on the street some, so I see nothing wrong with protecting the cooling system.
