Separating 3 piece wheels to change tires?
Old 07-14-2009, 10:12 PM
Han Solo
Han Solo's Avatar
Default Separating 3 piece wheels to change tires?
Anybody do this or do you still have the tires changed like normal 1 pc wheels?
Any reason not to separate 3 piece wheels to mount tires?
Old 07-14-2009, 10:47 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Change them just like any other tire. Don't mess with the wheels if they aren't leaking or you aren't changing anything. Some have a seal in there which can be spending to replace, or they are glued together,which can be a major pain. You will find it to be much more work to unbolt all those little guys, using a screw driver to pry the tire off the seat. In my eyes, DON"T MESS WITH THE WHEEL
Randy
Old 07-14-2009, 11:00 PM
Mojave
Mojave's Avatar
I would never take multi piece wheels apart to change tires. That's lot of little bolts that need to be torqued in the proper sequence, probably 2-3 passes, plus getting the seal between the pieces. Much easier to just change them the regular way.
Old 07-15-2009, 06:52 AM
parkerracing
parkerracing's Avatar
Only if it's a truck. /:\
Old 07-15-2009, 09:11 AM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've never taken mine apart
BTW if you DO take them apart, getting them so they don't leak is a real PITA!
LOL
Old 07-15-2009, 10:53 AM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Like others have said, leave them together. Depending on how the wheel is put together, some have seals, some you have to seal with a silicone sealant. Either of which you typically can not check while putting a tire on.
Nice thing about multi piece wheels is that you can change damaged items for less money than the entire wheel, and they are typically lighter.
Old 07-15-2009, 11:32 AM
Wah
Wah's Avatar
May I ask why you consider this method in the first place ?
To Separating 3 piece wheels to change tires?
Quick Reply: Separating 3 piece wheels to change tires?
