brake ducts
brake ducts
Has anybody put z06 front brake ducts on there c6 car. They seem to be very inexpensive from gene. Just wondering if they made any differance and how much trouble it was to do. Can't seem to find any
other post on this or a do it yourself install. thanks
Good luck.
FM
I've got the Quantum ducts. Not too bad of an install. Take off caliper/rotor. Pull out the stock ducts, use a dremel with a cutoff wheel to cut some space for the new duct. Line up and drill a 1/8" hole into the frame that a machine screw with a washer can fit into to hold the z06 inlet in place. Use a T55 torx to undo the hub bolts. Move the abs connector and secure with zip ties. Cut off the original abs connector bracket. Install the new spindle ducts. Connect hose (cut to length) to the z06 inlet with zip ties and to the duct guide with a worm gear. Put caliper/rotor back on.
Just a suggestion. If you are going to be heating up your brakes so much you need ducts, make sure you wrap your spindle ball joints and steering rod ends with header wrap or heat tubing too. Will help with longevity of these parts. Steel brake lines will also improve feel.......
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Unlike some other kits out there our ducts force the air through the center of the rotor making the vanes do the work and circulate the air around the rotor, wheel bearing, and pump through the caliper cooling the entire system.
ONLINE ORDERING:
LG BRAKE DUCTS
There is a bracket right behind the hub where you can attach the abs connector to. Hard to explain without pics, but it's pretty evident once you look behind there. And yes my ducts came with the race hose as part of a package.
How easy is the installation of the LG system? Do I need to remove the hub to install? If so, the Quantum style is a bit more user-friendly, but doesn't have the plate/shield that most of the other systems have (including other Quantum systems). Also, what are your thoughts on shields for the ball joint and steering rod ends?
St. Jude Donor '09
http://www.lgmotorsports.com/gallery...%20Install.pdf
The plate/shield for the Quantum is for Z06 or BBKs, not the stock calipers. Heat shield wrap will help to preserve components you're worried about.
San
