Pfadt suspension products on sale this week at MTI Racing
Pfadt suspension products on sale this week only until Friday July 17th!
Here is a rare sale on Pfadt suspension products. Please contact us by phone at (770) 919-7774 and we can send a set to you. If you need a shipping quote, please PM me.
-Jason
Pfadt Coil Overs have been around for years, offering ride height adjustability, 16 points of damping contol, proper shock length and shaft travel, patent pending aluminum/delrin upper mounts, easy installation and amazing ride characteristics!
All Pfadt Coil Overs ship with our patent pending aluminum-delrin split spherical upper mounts. The mount removes several inches of wasted space in comparison to a clevis style mount. This allows maximum ride height flexibility and shock travel in the tight packaging space of a Corvette. The mount does not consume valuable shock length and travel like a clevis style mount. The photo below shows the Pfadt Coil Overs on the left and a clevis style mount that we tested and abandoned on the right. You can see that our mount maximizes shock/spring travel while the clevis mount wastes valuable shock travel. The coil overs provide firm, poised handling without being harsh.
They are great as a stock replacement and a hardcore track shock and everything in between.
Pfadt Original Coilovers
List Price NOW until July 17, 2009: $1740
List Price Regularly: $1890
The Sport Shocks feature:
• Inverted body for low unsprung mass
• 16 points of adjustment with the **** right at the bottom for easy on car adjustments without using any tools
• Single point damping adjustment give control of both compression and rebound damping
• These shocks can be 'turned up' for track or autocross use, and 'turned down' for street use
• Compared to the Koni 3013 Sport, we even feature a lower spherical bearing mount in the front rather than a soft bushing
• Front lower spherical mount eliminates rubber bushings and provides superior durability
• Shortened body allows for lowering your car without fear of bottoming out the shock
• Pfadt Race Engineering proprietary damping and design specifically for the Corvette
• Easy, bolt on installation
Pfadt Inverted adjustable sport shocks:
List Price NOW until July 17, 2009: $790
List Price Regularly: $890
Shown on top is the newly released C6 Rear Tow Hook and below is the C5 Front Tow Hook. Front tow hooks require a little drilling, but we provide the installation hardware and Rear tow hooks install using the exhaust bolts (which makes it really easy).
Tow Hooks make it easy to prep any car for a track day.
Made in the USA of durable steel and powder coated red, you can count on our Tow Hooks to get your Corvette out of any situation!
Pfadt C5 and C6 Front and Rear Tow Hooks:
C6 Front: $125 (on sale NOW until July 17 for $110)
C6 Rear: $140 (on sale NOW until July 17 for $120)
C5 Front: $90 (on sale NOW until July 17 for$80)
C5 Rear: $75 (on sale NOW until July 17 for$70)
An excellent solution for high horsepower or high performance Corvettes, these mounts are a complete system to limit unnecessary movement. Pfadt Engine Mounts bolts to the factory location, so no modification to the car is needed.
Made in the USA and constructed with 6061 T6 aluminum and anodized for durability, pair our Transmission mount with our Engine mounts for an unbeatable package.
Pfadt Engine Mounts:
C5/C6 Engine Mounts NOW until July 17: $200
C5/C6 Engine Mounts Regularly: $250
It's a known issue that the factory eccentrics are prone to slipping. The camber kit allows you to achieve the maximum negative camber and eliminates the eccentrics so that the the settings don't slip. You'll be able to get more negative camber with the kit than is possible with the stock set up.
It replaces the bolts on the front upper a-arms with stainless steel studs and we provide stainless steel shims to set your desired camber and caster. The lower eccentrics are eliminated and the bolts are locked into their maximum position using a set of off-set plates. For the rear we provide a set of shims for the eccentric to dial in your alignment and make it stick.
Pfadt Camber Kits:
Steel Frame Corvettes NOW until July 17: $240
Regularly $290
Aluminum Frame Corvettes NOW until July 17: $300
Regularly $350
This new kit features hard anodize aluminum sleeves for improved durability, lubrication retention and lower friction! With the combination of the micro-pores on the surface of the hard anodizing and the new grooved bushings, the Pfadt Poly Control Arm Kit can retain more of the specially formulated grease then ever before! The system is now more effective at continuously re-lubricating the working surfaces for silky smooth operation! The front upper control arm bushings now utilize a retaining plate and snap ring to keep the control arm from flexing during track use. To make installation even easier many of the bushings are a two piece design!
The poly kit will make the Corvette respond to turns like the super car that it is! The factory bushings are known to deflect more than a ¼ inch in turns which equates to almost 1 degree of lost camber. With the poly bushings that deflection is gone and you'll make the most of your alignment.
Pfadt Polyurethane Control Arm Bushings and Sleeves
Steel Frame Corvettes NOW until July 17: $340
Regularly $390
Aluminum Frame Corvettes: $450
Regularly $490
-Jason
Pfadt Camber Kits:
Regularly $290
Regularly $350
Regularly $390
Regularly $490
